Question about Denon DN-SC2000 MIDI CONTROLLER DJ MIXER
Factory-reset to restore DN-SC 2000 - Denon DN-SC2000 MIDI CONTROLLER DJ MIXER
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
Factory settings
With IDES4, I can load factory defaults to my WK8000.
WK500 uses DATA MANAGER 5.0. If I am not mistaken, you can only save/restore/delete "user data" from and to the instrument.
FACTORY Settings are always unchanged in the instrument and it reset itself every time you power cycle.
Jan 15, 2014 | Casio Wk500 Wk-500 Keyboard Workstation...
Factory reset for the yamaha aw4416 workstation
The original factory settings of the AW4416 can be restored by recalling Scene Memory '00'.
1) Press the [SCENE] button in the 'AUTOMATION' section.
2) Press the [F1] button to display the 'Scene Mem' page.
3) Turn the (DATA/JOG) dial to select '00.Initial Data' on the screen.
4) Press the yellow [ENTER] button.
Reference: Operation Guide, p. 203
Sep 09, 2012 | Yamaha Aw4416 Aw 4416 Workstation
What is fatal error
Did you POSSIBLY try to do a firmware update and crash during the process? If so, then the OS is probably fatally clobered and you will have to send unit to a place to do a factory RESTORE. You should try a factory RESET first however. Do these:
http://www.themusichelpers.com/z/374154100001886
Jul 24, 2011 | Roland FANTOMG8
Rhythm accompaniment does not play. Start button flashes 3 green then 1 red. Began when someone randomly pushed number buttons on the key pad.
Do an initialization (factory reset) by holding the HIGHEST WHITE key down and turning on the power. Hold the key for an extended time until display confirms initialization complete. This will restore unit to factory defaults.
Jul 14, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
How to reset the pedal 25 ME? thank you.
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
Feb 15, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
My YAMAHA PSR-S900 is full of viruses! how can i proceed to clean it?
The computer processor in these is NOT subject to the viruses like PC's are.
Do a factory reset on the keyboard to restore factory settings.
Dec 27, 2010 | Yamaha PSR-S500 Digital Keyboard
The Sustain pedal does not work.
When push comes to shove, a factory reset never hurts.
Assuming you'd like to proceed with a factory reset, follow these steps:
This procedure makes it possible to restore the S08 to the original factory-installed Internal Voices, Multis and System settings.
WARNING: The current settings for all Multis and User Voices will be deleted. If the current settings and data are not expendable, create a backup before executing the Factory Reset.
1) Press the [UTILITY] button.
2) Press the [JOB] button. The 'FactorySet' screen will be displayed.
3) Press the [ENTER] button. The 'Sure?' message prompt will appear.
4) Press the [INC/YES] button to execute the Factory Reset. The 'Completed!' message will be displayed to indicate the procedure has been successfully executed.
5) Press the [EXIT] button to return to the Utility Mode.
Oct 14, 2017 | Yamaha Full-Size Keyboard
Denon DN-SC2000 MIDI CONTROLLER DJ MIXER Logo
35 people viewed this question
Top Denon Music Experts
Michial Gueffroy
Are you a Denon Music Expert? Answer questions, earn points and help others
