Question about NOBO S22E DS306 DS309 DS603 DX606 DX609 EP620 EP720 EP721 EP721MX EP726 EP727 EP727MX EzPro Projector Lamp
Nobo s28 projector vertical lines on screen
Where do I find the instructions on how to replace the bulb in my projector please
I could not go on, because from here I have to register my projector to get support, But perhaps you can get a manual here?
Customer Support
Jun 16, 2014 | NOBO S22E original lamp
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Ep716 has vertical line
IF THERE IS WHITE VERTICAL LINES IN YOUR PROJECTION THEN REMOVE THE MOTHER BOARD AND REFIT THE BOARD OR U CAN JUST PRESS IT FROM UPPERSIDE THE PROBLEM WILL SOLVE OUT
CHINTAN.A.SHAH
INDIA
Jul 23, 2008 | Optoma EP716 Multimedia Projector
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Vertical line
Hi there
The only way of fixing this is replacing or repairing the Mainboard.
This is a common Mainboard failure on Projectors
Nov 07, 2007 | Optoma H30 Multimedia Projector
Vertical Lines on the projector screen
When the vertical lines are displaying, open the projectors menu (by pushing the "menu" button). If the vertical lines affect the menu, it's a problem with the controller board and will need to be repaired. If the menu is NOT affected, it's probably a loose or damaged cable (Cable part# SP-DVI-A-R).
Oct 15, 2007 | InFocus LP70+ Multimedia Projector
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
NOBO S22E DS306 DS309 DS603 DX606 DX609 EP620 EP720 EP721 EP721MX EP726 EP727 EP727MX EzPro Projector Lamp Logo
50 people viewed this question
Top NOBO Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NOBO Office Equipment and Supply Expert? Answer questions, earn points and help others
