Question about Coby CT-P8700 Phone (CTP8700)
Cordless phone keeps reading, "lift handset"
When I try to use my cordless phone Colby CT-P8700, I cannot dial or hear dial a tone. One the screen it says to lift hand set. The base unit works. I can dial and use speaker phone, but the handset is the one that will not work. Help! Thanks.
  • Anonymous Mar 22, 2014
    How do you reset the handset, as it is the thing that is jammed?
    New Friend:
Nokia n95 is not getting power on
Posted on Feb 16, 2011
    Novelist:
  • 201 Answers
This would normally happen when the cordless handset was still in the charger stand. Are you saying it will still tell you to lift the handset after it's removed from the charger stand or base? I would not waste money buying a new battery as it is most likely not the problem but if you have more than one handset you should try swapping batteries. Removing and re-inserting the battery may reset the phone and clear up the problem as well.
Posted on Jul 07, 2007
SOURCE:
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
How to get a dial tone on your uniden 6.0 cordless phone
If you have a phone line that is active, lift the handset from the cradle, enter the number and press TALK. Or just press TALK if you want to verify that you have a tone signal.
Aug 27, 2011 | Uniden DECT 6.0 Cordless Telephone...
I purchased an extra handset to a AT&T uniden E2125 system. The phone instructs me to place new handset on main base to register handset. It has registered and now it reads, handset #5. When I try...
I've pulled up the user manual for your phone. Thank you for providing the phone make and model first, and the complete description of your issue!
The manual says the battery should be charged for 15 hours before first use.
You may be set to pulse dialing , even though the factory default is for tone dialing. If you push the 7 key, you would hear 7 pulses or clicks in succession. The dial tone will be gone once a pulse has been received. And you say there are clicks heard and no dial tone.
You can set Handset settings (Page 12 in the PDF copy) and customize how your phone works.
Hit MENU and use the up-arrow and down-arrow keys to scroll to the desired feature., this time called DIAL TYPE, then his SELECT. Looks like the sixth menu entry from the top after LANGUAGE.
It should read:
DIAL TYPE
TONE
If it says something else, perhaps PULSE, use those arrow keys again to change the Dial Type to Tone. Then use OFF to back out of the selection and again to clear the menu.
Attached is the link to the manual. Click the button on the screen to "Open as PDF" and you can open it in your PDF reader software or save it to your device for offline reading.
http://phone.manualsonline.com/manuals/mfg/att/e2125.html
Jan 07, 2018 | AT&T E2125 (650530003738) Cordless Phone
My telstra 8100 cordless phone keeps showing the word searchingnow i cant do anything with the phone.hope someone can help. Cheers
Place the telstra 8100 handset in the charger. Call any number while the handset is in the charger and it should dial out - you can hear the dial tone now. Take the handset out of the charger and you should be able to call normally.
cheers Matt
May 16, 2010 | Cell Phones
No dial tone
Sounds like you may have a problem with the one handset. Check to see if there is a volume control that you can turn up louder. It may only work while you have the phone in the talk mode. If that doesn't solve the problem then it sounds like the handset is bad. You may also want to plug a headset into the bad phone to see if it will work that way. Providing of course that the handset has a jack to accept a headset. Good luck.
Apr 17, 2009 | Uniden Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
I can hear, but not talk, on my ATS RA2184BB cordless phone.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
Mar 19, 2009 | Lands Phones
No dial tone
no dial tone. the handset shows "searching".
Nov 08, 2008 | Uniden Cordless Phone
GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Mar 19, 2008 | Thomson 26943GE1 Cordless Expansion...
Coby CT-P8700 Phone (CTP8700) Logo
134 people viewed this question
Top Coby Lands Phones Experts
Ekse
NOEL
NOEL
Tom Chichester
Are you a Coby Lands Phone Expert? Answer questions, earn points and help others
