Question about Kenmore Dryers
Symptoms of bad thermistor - Kenmore Dryers
My majestic fireplace lights and the burner lights and I turn on the switch and the burner stays lit for a minute or two then I hear a click and the burner and pilot light shut off
yes this would appear to me to be the classic symptoms of a bad thermistor , this little device proves that fire has lit (via heat) and keeps gas valve open , otherwise gas valve times out and shuts off (safety)
Oct 15, 2016 | Majestic Heating & Cooling
Water not heating
Hello. From the symptom you describe, it sounds like the control board has gone bad. I need the model number of your dishwasher to help you accurately. The control board uses relays to activate the different devices on the washer. Probably the relay for the heater is shorted or dead, or the control IC chip which activates everything per the stored program is defective.
Oct 01, 2015 | Dishwashers
GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Apr 24, 2012 | Refrigerators
Hi there, do you have the schematics for the Panasonic CT-27sf37b. This TV won't power up but making a high pitch sound near the thermistor area. Thanks.
Hi Richard,
First of all thank you for contacting Fixya.com regarding your TV problem.
You have mentioned that you can hear a high pitch near the thermistor area and the TV won't power up. I've saw also in another link that you already replaced the thermistor but the symptoms still persist. You stated that the thermister heats up, that is normal and not an issue in this kind of symptoms. You can power up the unit even without the thermistor in the board and check if the high pitch will gone or not. But I've suspected that the symptoms will remain the same because the pitch came from the chopper transformer.
I've encountered this kind of symptoms not only on panasonic CRT TV's but almost in all brands. And the major caused of fault is the faulty electrolytic capacitor in the Voltage regulator IC. Your unit used STRF6524 (mounted on the aluminum heat sink) as voltage regulator IC and it has an electrolytic capacitor on its circuitry. I would advice you to replaced it to resolve the issue. The largest electrolytic capacitor is not the suspect here (don't replaced it).
Also check for bad solder joints around the regulator IC. Cracked, cold, dried solder can produced that kind of symptoms. It is hard to spot, you must used magnifying glass and work in the brightest area or much better to re-solder the suspected bad solder joints.
I have various of Panasonic schematic diagram but most of them is a LCD and Plasma TV. I don't have this model no. but please check the chassis no. of your unit and I will try again to find it on my supplier to give it to you for free as much as possible because I've saw it HERE but I don't think the price is reasonable.
Please let me know if you need further assistance.
Again, thank you and have a nice day!
Kind Regards,
Jdvillanueva
Dec 07, 2011 | Televison & Video
Ricoh aficio 1045 - SC541
Fusing thermostat/thermistor open
Symptom: The fusing temperature detected by the
thermistor is below 10°C for 5 seconds
after the main power switch is turned
on.
Possible Cause:
• Fusing thermostat defective or out of
position
• Fusing thermistor defective or out of
position
• Power supply board defective
May 25, 2011 | Ricoh Aficio 1035 Copier
The fresh food side is freezing. There's nothing blocking the air inlet, the condenser coils are clean and the controls are off. What else could it be? I can't find a thermostat any where. I haven't...
Hi Louisa. Welcome to FixYa, I am Kelly.
The symptom your describing is usually caused by the air damper assy. failing to close. It can however be caused by a bad thermistor. There are 4 models of this unit that end in HEB, HEQ, HES, and HEW. I am using the model number MSD2657HEB and the parts that can cause your problem are the damper (item 7) this ink:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171229&diagram_id=28488614#d28488614
or the thermistor (Item 18) of the above link.
It could also be caused by the control itself (Item 13) but I doubt that at this time. I seriously believe it will either be the Thermistor or the Damper.
Thanks for choosing FixYa,
Kelly
Feb 18, 2011 | Maytag MSD2657H Side by Side Refrigerator
Ricoh Aficio 1013 error code sc 544
Fusing low temperature error
Symptom: Detected fusing temperature
remained abnormally low for 1
second during fusing operation
(below 140°C) or during standby
mode
Possible Cause: Fusing thermistor defective
• PSU defective
• Bad connection between fuser and
machine
Dec 18, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Ricoh Oficio 1515 tengo el eror SC 541
Fusing thermistor open error
Symptom: The fusing temperature remains lower
than the specified temperature by 20
degrees Celsius.
Possible Cause:
• Defective thermistor
• Incorrect installation of the thermistor
• Defective power supply unit
• Loose connectors
Dec 04, 2010 | Ricoh Aficio 1515 All-In-One Laser Printer
Vegetable keep freezing in the vegetable drawer
What brand and model? If it's a GE, I see the damper door brake and create the symptoms you hare seeing. If it's a duel evaporator model, the thermistor or control bd can be bad.
Aug 15, 2010 | Refrigerators
Ricoh aficio 3045 error code sc 541
Here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad thermistor,bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Office Equipment & Supplies
Dryers Logo
71 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
