Question about Sony Cyber-Shot DSC-S500 Digital Camera
Sony cyber shot 7.2 says turn off and on again
When i turn on my sony cyber shot 7.2 it says turn off power and on again and when i do it, it says the same.. tried the solution #1 given and it seems the problem of my cam is in main board... what does it mean and what is the best way to fix it... help please...
  • 3 more comments
  • victoria malabanan
    victoria malabanan Jan 22, 2009
    it's sony cybershot 7.2
    mpeg movieVX DSC-W7
    victoria malabanan Feb 08, 2009
    to suhbreena21, i hve tried ur advice but not sure if i did it right because i got a little prob in understanding your english, but it wrks a little, coz i can take pictures nw but cnt see the images in the lcd, but when its in the play mode i can see the pictures that i took..
  • gata69delici Feb 19, 2009
    i had the same problem turn off and on again , but i fixed it the lens seem to be stuck. but now the image is blurry? i dont know what setting should i change. thank you
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    DSC-W7, Its lens problem and lens assembly needs to be replaced.
    Cost of repair would be over then camera worth so better to buy new camera.
    Problem looks with lens assembly. Please intimate exact model of Sony cybershot.
It just happened to me and was looking for info on it and this popped up.
This might sound risky,but it worked for me.
Well it should me like stuck about 7/8 its original size when on and when look at from above,it is tilted.
What i did was push it a little to make it straight,and then i just pushed it back in with enough force to make it move but not jam it.After I pushed in back in,i turned it on,and Wahh Lah!
It worked for me:D
Posted on Feb 08, 2009
  • suhbreena21 Feb 08, 2009
    I'm sorry for my English,though I may have made some grammer mistakes,as i was excited i fixed mine:D
    I am American.
    In the US.
    But what i meant to say was,
    I was searching information on this problem and if anyone had solved it,
    and you question popped up.
    So i clicked on it;messed with my camera,and this is what i did.
    I got the lens,pushed it the opposing side it was tilted to,and then i applied enough force for the lens to go in without jamming it.
Turn the flash on
Sure your battery has enough power to charge the flash? charge the battery and try again.
Mar 16, 2015 | Sony Cyber-Shot DSC-W570 Digital Camera
Every time i turn on sony cyber shot the screen states turn the power off and on again whats wrong
Hi change the battery and check it again if steel the same the spring that keep battery connected may need to stretchgood luck
Oct 19, 2011 | Sony Cyber-Shot DSC-S500 Digital Camera
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
As soon as i turn it on it beeps and says turn the power off and on again the lens wont move in and out
I'm sorry that the camera display the eror: turn the power off and on again. If turning the power on and off again does not resolve the error message, try doing a power reset. Refer the URL for the information to reset a Cyber-shot® digital still camera back to original factory settings:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C265373
If the issue is still unresolved, service may be required.
Jan 04, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W150. when powering on the
allienment with the mother board and also failure of the sensors of the lens unit,so contact sony service
Mar 01, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber shot 7.2
    Mostly this symptom shws in two ways First is lens and second is main board.Just try it as i said. First dont turn the power on just press PLAY button from which u see the pics.If it turns on and you are able to see picture display on the LCD  then switch it to pictur taking mode.It means that the problem is in lens.And in doing this procedure it shows nothing on the lcd and not go to play mode and message "TURN THE POWER OFF AND ON AGAIN"appears Then the problem is in main board.
Nov 02, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
When i turn on my camera it says Turn the power off and on again
turn it on
take hold of the end of the lense, then pull and twist gantly you may hear it click but dont force it then turn off and on again this may solve your problem
Oct 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber -Shot
try gently pulling and twisting the end of the lense and i mean gentle dont pull till it pops than switch it off and on again and you problem should be solved
Jun 21, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-Shot DSC-S500 Digital Camera Logo
168 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
