Spin cycle on washing machine not working
All cycles work except spin
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
The spin cycle relies on the sensors turning on the sump pump to pump out the water and a solenoid valve to open to allow the water to drain. They are both controlled by a water sensor located in the bottom of the machine. If it does not sense the water it will not let the pump start or the drain valve open. Check it out.
Posted on Jan 12, 2013
  • michael john webb Jan 12, 2013
    worked it out the lid lock had a broken wire on little switch ordered new one all good cheers for the reply. joined the two wires together and it worked so it thinks lid is locked
  • Leigh Perlmutter
    Leigh Perlmutter Jan 12, 2013
    Good for you!
Everything works but it does not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue. Click on the link below for the complete and detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Dec 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 12, 2010 | Washing Machines
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
