Question about Hitachi Ultravision P50S601 50 in. Plasma HDTV
La luz de encendido solo parpadea y esta la pantalla negra
Se dejo de ver cuando jugabamos videojuegos
4 Suggested Answers
  • 247 Answers
SOURCE: recuadro negro en el centro de la pantalla modelo 55fx20b hitachi
in english please
Posted on Jan 11, 2009
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
rayomacqueen
SOURCE: mi televisor se prende y
mi tv ultravision hitachi prende y se apaga lo desconecto y lo conecto y prende y hace lo mismo y m parpadea la luz roja d temp q sera ?
Posted on Jun 22, 2012
Zte n9511 la pantaya esta negray no se puede ber nada
Lo primero seria buscar en Google "Como hacer ZTE N9511 nuevo de f?brica". Si puedes ver videos mucho mejor. Esto lo que hace es entrar en una secci?n del celular conocida como recobrar, o recovery en Ingl?s. Si el celular prende, y logras acceder al recovery, que se pueda ver la pantalla, entonces puede ser una falla del SO (Sistema Operativo). Mediante el recovery puedes hacer nuevo el celular como si fuera de f?brica, o sea, como cuando se compra nuevo de la tienda. Esto repara el SO, haciendo que el celular vuelva a trabajar.
Este video es el que mas se asemeja a tu modelo.
Apr 02, 2015 | ZTE Cell Phones
Tengo un acer aspire 5100 bl51 cuando la enciendo en la pantalla no aparece nada y esta toda negra no se que pudo suceder estaba descargando videos y de pronto se oscurecio la pantalla se escucho un...
Desconecta la bateria principal y Desolda una bateria chiquita que trae en la tarjeta madre (Posiblemente este debajo de la tarjeta Inalambrica).
Luego manten precionado el boton de encendido durante unos 10 segundos. Luego conecta todo y Listo. Ya que compruebes que te da Video le soldas nuevamente la bateria. Eso es Todo
Aug 30, 2012 | Computers & Internet
Parpadea la luz verde de encendido .la luz roja de lamp tambien
SOY NICO,Jose si es la D que parpadea es el sensor ,3 gear pressure switch tienes que cambiarlo, me pasaba lo mismo lo cambie y problema resuelto,cuesta 67 dollars con los taxes en el dealer,lo puedes cambiar tu mismo,busca este codigo en internet P0845 y mira las fotos donde esta ubicado,esta es la imagen ,quita la rueda del lado del chofer y lo veras,para cambiarlo desconecta el negativ bateria,,4_28_2012_1_09_18_am.gif
Apr 22, 2012 | Cars & Trucks
Eee pc 90ha mb pantalla negra no enciende
Tengo un pc eee top et1602 y la pantalla no enciende se queda negra los led si prende el ventilador tambien ando preocupado si alguien tiene repuesta a este problema por favor enviarme un correo digitalpaint2012@gmail.com o por aca
Feb 16, 2012 | ASUS Eee PC 900 PC Notebook
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Sep 12, 2010 | Televison & Video
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Dec 29, 2009 | Televison & Video
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Hitachi Ultravision P50S601 50 in. Plasma HDTV Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
