Question about SWANN Home Security
Set up manual SW361-OBC
Manual required
Obc won't link to states computer
OBD communications require 12V at the DLC connector. Check for blown fuses, especially the cigarette lighter/power outlet fuse.
Dec 06, 2014 | 2009 Mitsubishi Eclipse Spyder
2003 trailblazer ext obc test doesnt register
Its an OBD connector.
Check the CIGAR fuse in the under hood fuse block.
Its probably the thermostat. P0128 code?
Apr 02, 2013 | 2004 Chevrolet TrailBlazer
E36 1995 325i bmw, how to remove obc from dash to replace bulbs
removing it is easy but while you put it back remember there is a clip inside the assembly which you have to pull it back before fixing the OBC back. dont apply force it requires mind.......
Nov 07, 2009 | Car Audio & Video
Need to change bulbs in obc 1995 bmw 325i how do you remove obc from dash to get access to bulbs
its alot of work and chances are your instrument panel is a board and lights have to be un soldierd and re doliderd in.difficult.
Nov 06, 2009 | Car Audio & Video
328is obc
obc press the 1000/100/10/1 buttom on the overside of unit to set the time and when u put the correct time in press the set buttom on the obc to set it in
Nov 24, 2008 | 1997 BMW 328
I am unable to open easycreator suite 10, but can oen the other applications i have windows xp
I am a relatively savvy user.. wish I would have researched user opinions before buying this package from my warehouse membership store or from anyone for that matter! Replacing EMC9, installation was difficult to complete as the wizard did not successfully uninstall certain modules (update manager) of the previous program. After installation finished, program suite would not launch from desktop icon or individual program listings. solution provided was a tedious, time-comsuming complete "clean install procedure" not for the faint of heart. It did seem to work allowing me to launch the program - once. I use Norton Systemworks and always run One Button Checkup (OBC) to keep the PC humming. OBC corrected registry "problems" and once again, EMC10 will not work! Online chat reveals that I will need to reinstall EMC10 every time after using OBC!! "OBC removes a registry key that EMC10 needs to function - we are working on a patch" If I could, I would return for a refund, as it is, I will refrain from using until they make it work correctly.
Aug 19, 2008 | Computers & Internet
Home Security Logo
22 people viewed this question
Top SWANN Home Security Experts
Electro Med Services...
L Pfaff
L Pfaff
Da Doc
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
