Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Lg front load washer drum bang
The drum bangs around and has a squeaking sound. I replaced the dampers and still doing it
  • LG Master
  • 17,129 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 12, 2013
  • 3 Answers
SOURCE: LG Tromm Water filling
water hammer valve at home depot fixes problem for like 20 bucks
Posted on Mar 21, 2008
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 1462 Answers
SOURCE: banging pipes when washing machine fills
it is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
Posted on Sep 17, 2008
stradeteox
  • 88 Answers
SOURCE: LG Front load washer LE error code
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
You can order parts by your location by CLICKING HERE
Posted on Jan 08, 2009
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
Posted on Feb 01, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
WMA30 Front loader
when a machine gets old it is always normal for the vibration and banging to occur, then, after the vibration it settled down smoothly.this is due to worn fan belt .bearings worn out and the preasure on the spindle.so dont get alarm .but you will soon have to replace the washer as the banging and the vibration will get worse eventually.or change the fan belt.and replace bearings.which can be done by a qualified personel.good luck.
Jun 09, 2007 | Hotpoint WMA30 Front Load Washer
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Making a banging noise on spin and throwing itself around the kitchen. i think the drum has come loose?????
well sort off.
likely is that the dampers on the underside of the drum have failed. (they are like shock absorbers)
The drum is also suspended from a couple of springs, you also need to check these.
To check springs the lid needs to be removed.
There normally are 2 dampers attached to the drum and the frame.
They are accessed by tipping the machine onto its side.
However the machine is heavy and make sure you disconnect power and water if you want to investigate.
Cost of new dampers are around 50 each.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Baumatic MEGAWDSS Front Load Washer /...
Washer is making a banging noise when spinning, redistributed the load and got same results, legs are stable and even
It is possible that the dampers mounted to stabilise the drum on motion is defective. The suspension springs can be weak and aggravate the drum to aggitate out of balance.
So check from the underside for the dampers, replace if soft and test.
Aug 23, 2010 | GE WSXH208A Front Load Washer
My kenmore front loading washer is make a bad banging. washer is level and sounds like the inner drum is banging against the outer drum. if this is possible what may be the cause. any help is appreciated
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2009 | Kenmore Washing Machines
Can not run spin cycle bang bang bang
May 04, 2009 | Washing Machines
Maytag LAT9806AAE- Top Load Waher- Loud Banging During Spin Cy
Damper pads, P/N 203956, $23 at searspartsdirect.com might do the job. Can't put them in yourself though, unless you are the Maytag man. Look for felt pads at the bottom of the cabinet or black dust around the damper at the bottom.
Other, more expensive problems might be a warped drum or a bad transmission. Are the springs o.k.?
Jan 18, 2009 | Washing Machines
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
336 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
