Question about Samsung Televison & Video
The color red jumps on my Samsung - Samsung Televison & Video
  • kent Wilson Jan 14, 2013
    The TV is a Samsung Model 630, model #LN55C630K1F. All colors, except Red. Are fine. The color red jumps up and down on the screen during screen.
My samsung tv model hl-t6187s has no red
The red LED chip has burned out. Samsung purposely overdrives the red LED to make the colors look better and the red one usually fails from heat.
Apr 18, 2014 | Polaroid Televison & Video
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
Color picture jumps in and out of normal color mode . . .
You have bad solder connection in or around the Jungle IC and or color processing Circuits. Most commonly the area is the color cyrstal, located on the main board.
Oct 10, 2009 | Televison & Video
Sony Kp51ws500 Jumping Colors
you will want to replace the whole board
Jul 07, 2008 | Sony KP-51WS500 51" Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Red
ok when you say all red there is not other colors at all?
otherwise i would recommend this if you see other colors.
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Dec 18, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
219 people viewed this question
Henry  Thomas
Henry Thomas
