Question about Dishwashers
The water pipe in the wall behind the bathroom sink vibrates/knocks on the wall routinely. Opening the water spigot will show pulsing water, and ultimtely stop the vibrating. The noise started out maybe once or twice a day, and is now vibrating three or four times an hour. The house is new as of 2007 and the problem has only recently begun. Do I have to open up the wall and cushion the pipe, or secure it to a stud?
    Top Expert:
  • Dishwashers Master
  • 45,112 Answers
Open up the wall and cushion the pipe, or secure it to a stud.
Posted on Jul 19, 2017
2 Suggested Answers
  • 52 Answers
SOURCE: Vibrating dishwasher pipes
a plumber needs to install a anti knock pipe at the valve under the sink ....this should stop the vibes ...should only cost about 50 -75 bucks ...depending on the per hour rate of the plumber
Posted on Jul 26, 2009
I hear a knocking noise behind the wall when I use the hot water. What could it be and how do I get rid of it?
I had something similar, but I would call the noise more like 'ticking'. The problem was that hot water would heat up the plumbing vent piping (plastic) for that bathroom and it would expand and then contract (after shutting hot water off). As the pipe 'grew' it would make noise sliding through the opening in the ceiling header. It seems that builders had stuffed loose fiberglass around the pipe there that served to let the pipe move freely. The fiberglass had fallen out and the pipe was rubbing against the wood and making noise. Stuffing new fiberglass in the opening around the pipe fixed it.
Oct 29, 2014 | Water Heaters
Toilet bowl will not refill
It is possible that the vent pipe behind the toilet is clogged (or was not installed properly). Some bathrooms are set up with one shared vent pipe, and a clog in one of the lines leading to it can cause similar problems.
The vent pipe in each bathroom does 2 things:
1: it lets the sewer gas go past the bathroom and up out the roof so you don't get sewer gas in the house.
2: It breaks the siphon as water goes from fixtures down to the big sewer pipes in the house. If it isn't working for a sink, it's not much of a problem because air gets mixed in with the water as it does down the sink, and this breaks the siphon. But in a toilet, it jsut keeps pulling water down the pipe until the water level in the toilet gets low enough to let air into the pipe, breaking the siphon.
It's not an easy problem to fix and often involves removing walls to get at pipes.
A plumber can bring a snake tool and try clearing the pipes from below or from the roof, and might even be able to bring a steerable snake that lets him control how it goes through the pipe.
Apr 19, 2014 | Kohler Home
Fixya login
Unfortunately this sounds like more than a blockage. If this was a blockage water would not drain, maybe fill in sink or dishwasher etc. If water is coming from walls probably means it is leaking from drain pipe in the wall. Which would mean opening wall to find leak.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Aug 14, 2013 | Mountain Plumbing Plumbing
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Nov 14, 2012 | Plumbing
Air in bathroom cold water pipes
You have to install anti knock pipes into your plumbing, it's quite common. Go to the local home center you can by pre made or make your own as I did when remodeling my basins. Good Luck..
Oct 20, 2012 | Home
I have 2 bathrooms with a common wall. We hear a constant low tap of the pipes in the wall between the bathrooms. We have checked toilets, sinks, faucets, etc for leaks. Sounds as if there is pressure or...
You have water hammer effect it is caused by a fast closing valve,it can be solved by installing a water hammer arestor in the plumbing line or maybe the water pressure is too high and a pressure reducing valve can be installed in the main water line.(the pipes in the wall are not secured properly that's why they vibrate)
May 19, 2011 | Plumbing
When hot water is turned on the pipes make this vibrating sound. i have two sinks in my bathroom. When I turn the hot water on on sink 2 the pipes vibrate. Sink 1 is fine.
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
Aug 22, 2010 | Kohler Plumbing
I have two bathrooms directly under each other. The hinges on both cabinets (under the sink) are rusted and the pipes going from the wall to under the sink are also rusted. There are NO LEAKS ANYWHERE in...
You can't stop condensation or humidity in the house, especially in the bathrooms. A few choices: replace the hinges, or oil the hinges with WD-40. Install a vent fan (even though you have a window) and replace the pipes with PVC pipes. Metal drain pipes will always rust, because they drain water. Replace all under sink drain pipes with PVC
Mar 13, 2010 | Home
I hear running water behind my sink in the wall. how can I confirm its behind the wall and what can I do to fix it. I can't find no water on the ground in any room. meter reader says water is always...
If it is running constant, Check the toilet(s) flappers in the tank(s). If warer is leaking in the wall, You would know it, trust me.. To ck the house, Turn off the water to the house and then go ck the meter. Walk the yard and around the house looking for water perking out of the ground.Don't turn the water off at the meter. There should be a valve at the point the pipes enter the house or foudation.Good Luck_Ned_
Oct 21, 2009 | Belle Foret Bathroom Sink Faucet -...
Leak from bathroom sink behind the wall
hello , usually there will be water supply lines coming in from behind the wall area and if it isnt leaking at the supply valve it self then you may need to open up the wall area behind the sink and find out what is leaking it depends on what type of pipe is used most likely you have cooper tubing and sometimes these tubes after a while may leak or form small holes or it may be a leak at a soldered joint remeber there are 2 lines one for hot one for cold and you can turn the off by shuting off your water at the main valve then repair the leaking area.
Oct 10, 2009 | Belle Foret Bathroom Sink Faucet -...
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
