Question about Dishwashers
Kenmore 6651303 dishwasher
Dishwasher starts then at different times in the cycle it stops no lights sometimes it will restart other times not starting at all
  • 17,130 Answers
Possible that the fault seems to be malfunction on the PROGRAM CONTROLLER UNIT. You need to remove and check for loose joints or connectors.check for moisture within the board which could cause this erratic operation. if so use a hair dryer to warm .
If this wont work the control panel must be removed and checked or replaced.
Posted on Jan 12, 2013
  • 249 Answers
SOURCE: Kenmore 665 dishwasher washing light stays blinking
could be faulty outlet pump
Posted on Nov 28, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
It says in the manual to check the heating element.
Posted on Sep 10, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
Posted on Jan 26, 2009
My kenmore dishwasher wont start at all now. It used to start if you pushed certain buttons a bunch of times but now the lights next to most of the buttons light up but it wont start a cycle. any ideas?
Hello
Ensure that the dishwasher is connected to a working power supply. Check the local fuse or circuit breaker and restart as necessary.
Open and shut the door firmly until it latches into place. The dishwasher will not function if the door is not latched into position.
Select the desired cycle and press the cycle button firmly, as you must choose a cycle in order for the dishwasher to begin operation.
Look at the water valve that is connected to the dishwasher and ensure it is turned on.
Turn off the dishwasher and unplug it from the power supply to reset the unit. Plug it back in and select a new cycle. Select "Start." If the dishwasher still does not start, contact an authorized service technician.
Sep 11, 2011 | Kenmore Dishwashers
Dishwasher is less than a year old. Once in a while it will stop about 10 minutes into the cycle, then the display lights will blink. Sometimes it will stop and the lights wont blink so we will come back...
I would most likely guess a faulty latch....it will cancel the cycle, thinking that the door has opened, and the lights will flash. After a certain amount of time, it might "time out" and reset and the lights would stop flashing. Unfortunately it's a bit of a guess, but the other option would be a bad control board.
Apr 07, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Jan 24, 2009 | Dishwashers
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
May 09, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
