Question about SanDisk Sansa e250 MP3 Player
MP3 player fails to recharge when plugged into USB port of my computer
Until a few days ago I could recharge my MP3 player by connecting it to a USB port on my computer. Now I get an automatic message that says the device is not recognized, that I should disconnect and try again and if that fails (it does) then the device should be replaced. This afternoon, July 4, 2007, I took my MP3 player back to the point of purchase, Telecity Electronics on Yonge St. in downtown Toronto, Ontario, Canada but the manager was extremely unhelpful. The MP3 player was purchased there just over a year ago, and so is no longer under warranty. In any case the manager said that Telecity does not honour manufacturer warranties nor does the store service what it sells, although I was led to believe otherwise when making the original purchase. Of course I would like to be able to continue using my MP3 player but cannot do so until it is recharged. Any recommendations will be appreciated. Thanks in advance to whomever is able to respond with a solution to this problem.
  • 1 more comment
  • Janis Rapoport Jul 10, 2007
    Thank you for your advice, which I sincerely appreciate. However, I cannot find the four screws on the casing to which you are referring.
    After reading your message, I even took the MP3 player to another store that used to sell them but no one there could find the screws either. In fact I couldn't get anyone to try to remove the casing to locate the battery because no one would risk breaking the MP3 player by trying to get it apart.
    Which type of battery does the MP3 player use (should I ever get it open)?
    Thanks again.
    P.S. I would like to know how to get the MP3 player open. It is silver on top and blue on the bottom.
  • krazychick61 Jan 27, 2008
    when i plug my mp3 in the usb it says not reconized and i dont have a cd or anything for it what can i do???
  • Anonymous Dec 25, 2008
    When I plug in my sandisk the rechrge indicator does not show
The only possibility i see is to replace the battery in the casing, just take out the 4 screws in the back and pop the batery out, then replace it with a new one. after a while the battery will diminish and need replacing, so that might be now for you... ^_^Pyrotorch^_^
Posted on Jul 05, 2007
How do I recharge my mp3 player? I have lost my manual.
MP3 players are charges with the USB cable. Connect the cable to your player and then plug it into the USB port in your computer. While it is charging you can download mp3 music files to your player.
May 16, 2011 | SanDisk Sansa Fuze MP3 Player
I juat purchased a pholips go gear vibe mp3 8 gb. is it a rechargable player?
Most media players have a rechargeable battery and it is charged by connecting the media player to USB cable and then plugged into the USB port on a computer.
Mar 10, 2011 | Philips GoGear ViBE Digital Media Player
Will not recharge
Have you tried plugging this into a USB2.0 port ? sometimes, some of the usb ports dont not have enough power to charge some players.
Which is which is why, sometimes, (seen very often with external hard drivers) there are two usb plugs on the computer side which needs to be connected.
1) Try another USB port, or another computer (especially is this is a laptop, some of the ports are under powered, to save power)
2) if you have an AC Adaptor to charge this, try it with that
Feb 20, 2011 | SanDisk Sansa e200 MP3 Player
How i can recharge the battery of my scandisk?
Connect the USB cable to the MP3 player then power up a computer and plug this MP3 and cable into the computer's USB port.
You can also charge it by purchasing a 5V USB power adapter and plugging the MP3 player and cable into this adapter.
Jan 04, 2010 | SanDisk Sansa e250 MP3 Player
When i plug in device in to a usb port my computer freezes up
have you tried a different USB port because theres two types of usb port & one on the back has pin's inside it check that these arnt bent or touching you should use the side ports for your basic everyday external devices.
Aug 12, 2009 | Computers & Internet
Recharge battery without a/c adapter
pretty much all mp3 players can do that, you could just find a cord that will let you plug it into a wall plugin, I use a cord i got with a blue tooth ear piece to charge my mp3 player =P
Apr 08, 2009 | Zvue Spirit MP3 Player
RCA H125A
That could be a hardware failure - requiring replacement, but go to the RCA website and get the Recovery tool. I'm assuming that you already tried resetting the player. If RCA's methods fail, try this:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jul 06, 2008 | RCA Lyra RD2763 MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
hii
just re plug it and see what happens or.. if you have wall mount charger with a usb connect .. then us it ... and if all fails... open ur player and disconnect the batter for a minute and reconnect it and then put it to recharge...
let me know what happnes..
tc
May 28, 2008 | SanDisk Sansa MP3 Player
Inovix imp-1112 mp3 player problems
Hi. I've had similar problems with the same model.
Have you tried a Firmware re-install yet? If not, do that first using the CD supplied with it.
Whilst it's plugged into your USB port, it'll hopefully also get a bit of a charge.  I notice on mine that the player will only charge from the USB port when the side on/off switch is in the 'on' (up) position, although there are times when the computer will 'reject' the player with the switch in this position - a series of 'ding-dongs' as it connects and disconnects from the USB port!
If this happens to you, just keep trying!  Come back to it each day, and try another Firmware re-load!
Mine took a few days, but then decided to come to life - weird machine!
Sep 23, 2007 | Inovix iMP-20 MP3 Player
Ipod wont recharge
Try a regular AC wallcharger. You can get one on Ebey for under $10.00 with shipping. I have had similar problems and this seemed to solve it when the battery had completely discharged.
Aug 02, 2007 | Apple iPod nano
SanDisk Sansa e250 MP3 Player Logo
360 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
