Question about Olympus BX40 Microscope
How to change a bulb on a olympus bx40 - Olympus BX40 Microscope
Tip
Bulbs for Microscopes Has it really failed
Often bulbs can look perfectly intact even when the have actually failed.
Use or borrow a multimeter and test the continuity on its continuity setting. It normally buzzes when you put the leads together on most multimeters.
This simple test , plus testing fuses can save calling out an expert
on Oct 20, 2013 | Olympus BX40 Microscope
Subsidy code
Specify the Motorola Mobile phone model correctly.You have specified only motorola battery model.To get subsidy code,i would suggest the site Classicunlocking.com after getting code for motorola phone and unlock it step by step using the unlocking instructions.
Jul 23, 2013 | Motorola Mobility (BX40) V8V9mV9hI9U9...
Olympus mju300 flash doesn't work
Perhaps the manufacturer can but we common people do not have their abilities
Dec 04, 2017 | Olympus MJU 300 Digital Camera
My set shows on display invalid battery.and not to be charge.my battery name is bx40.my set model is motorola v8,
REMOVE BATTERY > Clean the terminals specially middle terminals of both battery&phone with dry cloth.install battery. If the problem persist then change battery.
Mar 23, 2011 | Motorola Mobility RAZR2 V8 Cellular Phone
Does a bx51 motorola cell phone battery replace a bx41
Thanks for visiting Fixya!
I believe you meant a BX 50 and not a BX 51. Yes, the BX50 and the BX41 are interchangeable.
Feb 25, 2011 | Motorola Mobility (BX40) V8V9mV9hI9U9...
The flash will not "go off"
You could have burned bulb out.
But try checking settings for flash make sure they are turned on. You can due this through the menu functions.
Mar 08, 2009 | Olympus Camedia D-510 Zoom Digital Camera
Flash indicator keeps blinking
i have the same problem. i dont think the flash is working.. i think the bulb needs replacing. i wish i knew a place to get it fixed or a place to buy a bulb...
Aug 05, 2006 | Olympus ? Stylus 500 Digital Camera
Olympus BX40 Microscope Logo
201 people viewed this question
Top Olympus Science & Laboratory Experts
TimHu
Level 1 Expert
Are you an Olympus Science and Laboratory Expert? Answer questions, earn points and help others
