Question about Tascam DR-05 Portable Digital Recorder
When i have recorded something and play it back the recording is phasing
    Problem Solver:
  • 7 Answers
My first thought is your play back volume is too high and your file choice is wrong. While your playing back your recording, press the down arrows on the ring of buttons on the front of the recorder. The top and bottom button turn down the playback, the right and left buttons turn down the "recording" input sound. Set your file area setting to "all files". Better yet set your recorder to these settings it will work well for most recordings. I got this on a 3x5 card and check to make sure I got these setting before every recording.
1. Input "on" 2. Recorder onboard speaker "off" when recording. ( not a big deal I just do it) 3. "low cut" set to 80 ( this will help filtering house background like your AC unit sounds from lights and if out side some sounds from the open air ) example; 124hz is the note B. So we don't want cut that out. So 80 is good for indoors haven't used it outside yet. This next setting is key for phasing and squalls and recording at all and that number 4. 4. Setting "Area" to "All Files". ( Not sure what all files does but it started working after I changed that to All Files so I don't care why just do it.)
Once you get these settings right all you need to do is make sure input is "on", and watch the peak light which is left of the record light. Make sure the peak light doesn't come on very often, turn down your input volume just a tad if it is, just under that is perfect. I always got to think of this to and that is make sure when you playback you must "turn off" ..."In put". That input on or off and and input volume is what I am always thinking about when working with this recorder. I have had this recorder right in the middle of us with a drummer, bass, two sometimes three guitars and a conga player. All playing in a circle. I set the recorder right in the middle of us on a camera try pod about 4 feet high and the recording are great. Just watch the peak light and it will do surprisingly well. I love it and the band is impressed. I sometime put it front of us when we play in a stage straight line but the drummer is not heard as well. So stick it right where you are and watch the peak light so it won't come on. enjoy, I am. patbham
Posted on Jun 15, 2014
RCA VLP37H needle arm won't advance to play record...moves backward, then seats down again
You will probably have to take the bottom off to see what is happening inside. The thing could have been tampered with by someone try to fix something. So it's not something that you know was previously working. With a bit of luck it might need a bit of grease to get it going. But you never know with a second hand model!
Aug 17, 2014 | Audio Players & Recorders
Buttons Play or Play&Record will not stay gown
There is a feature, in a cassette recorder, when a cassette is "locked" to prevent it from erasure or record, if you break out a little notch on the back of the cassette When this is done, you can't press the record button. Perhaps something connected to that feature is blocking your deck. If the back pice of plastic left of the hole, is gone, the cassette is "write protected".
Look inside to see the "pal" that is in the deck.
Or perhaps your deck has a relais that should hold the button down, but it does not get any power? 6f4f166c-a584-4d29-9da6-e149a704708f.jpg
Jan 16, 2014 | Audio Players & Recorders
I use Samsung C3010. when playing music player, I don't hear any voice. I only hear the instruments. I've tried many airphones but nothing. can it be solved?
How are you obtaining the music that you play on the Samsung C3010? If you're recording the songs yourself, it sounds like you are recording one channel out of phase with the other. This phasing "effect" is how vocal eliminators work. Try playing back music from another source and see if the vocals return.
Aug 14, 2013 | Audio Players & Recorders
How to record with Multi-effects feature on Tascam DP 01
I'm not familiar with the Tascam DP-01 but many multi-track recorders don't commit effects to the track until the mixdown phase. The thinking being that you cannot eliminate a "bad choice" effect once it's down to tape (old school term) and so they allow adding the audio tweaks at the final stages of recording. Here they hope you can appreciate the entire mix and then decide what sweetners to add.
Feb 21, 2013 | Tascam Audio Players & Recorders
How do I get my Meowsic keyboard to record? The record button lights up when I hit it, but nothing happens when I hit the play button.
We just got one of these today at a thrift shop. I thought it was supposed to record what you say into the microphone but it doesn't. It records your "compositions". Press "record" then play something on the keyboard. Then hit "Play" and it should play it back for you.
Aug 27, 2011 | Battat B. Meowsic Kitty Kids Keyboard
Machine appears to record per instruction manual but will not play anything back and the instruction manual includes NOTHING on playback except to hit STOP when we're through recording, back up to the...
it appears to be recording but is it really?
when you are recording there are two levels you should see moving up and down on the screen. the input volume and the recording volume per track. dont forget to arm the track. tascam has a silly way to arm the track on some of there unit. its combination of buttons. something like hold down the record button and press the track arm button then release both. when youre ready to record press play.
Feb 22, 2009 | Tascam DP01 All-In-One Recording Package...
Don't copy
If the VCR tape has copy protection on it, I could see it doing this.
Jan 13, 2007 | Zenith XBR413 DVD Recorder
Tascam DR-05 Portable Digital Recorder Logo
87 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
