Question about GPS
How change Garmin forerunner 210 from miles to km
5 Suggested Answers
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
SOURCE: how do I change my garmin forerunner 205 from miles to kilometers
To change this setting go to the menu on the Forerunner by pressing the Mode button then follow the steps below:
  1. Select Settings
  2. Select General
  3. Select Units
  4. Select Distance and/or Elevation and change this to Metric if you wish to see the measurement units in kilometres and metres, select Statute if you wish to see units in miles and feet
Posted on Jan 23, 2010
riceski
  • 1851 Answers
SOURCE: Forerunner 305 GPS Receiver: Is it possible to change the battery in a Garmin F...
Yes you can. Go to the Garmin Website and simply email them asking for the price of the battery and instructions on how to replace your specific model and serial number as they changed in mid year many times.
Posted on May 04, 2010
  • 638 Answers
SOURCE: Forerunner 305 GPS Receiver: How can I change my Garmin 305 from miles to kilom...
Page 48 of your manual, Changing Units of Measure. Settings > General > Units
Posted on May 20, 2010
How can i change miles to km in my garmin forerunner 10 gps watch?
Press the inverted triangle button, then settings, then setup. You will be able to change the unit of measurement there. Hope it works.
Aug 18, 2014 | GPS
Tip
Garmin Forerunner 210 manual.
Follow this link and download Forerunner 210 manual. <a href="http://static.garmincdn.com/pumac/Forerunner_210_OM_EN.pdf">http://static.garmincdn.com/pumac/Forerunner_210_OM_EN.pdf</a>
on Feb 26, 2011 | Exercise & Fitness
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
Frozen screen
I do not have your specific model. However, others had luck by following these instructions. "Plugging the watch into the charger then holding down the light button for 15-20seconds did the trick." Did you try that?
Jul 20, 2017 | Garmin Forerunner 210 Gps-enabled Sport...
My garmin 210 just went to blank screen
saving activity is due to a voltage problem check your connections and don't leave it in the sun!
Sep 06, 2012 | Garmin Forerunner 210 - Unit Only
Could I use the Nike+ pod together with a Garmin forerunner 210?
Nope: Different types of signals.
That being said, there is a foot pod that Garmin makes if you want that type of data sensor. The GPS in the 210 is more accurate than the Nike+ pod, and the Garmin foot pod is about equally accurate with the 210, but allows you to use the watch when there is no GPS signal
Dec 18, 2010 | Watches
Change display from miles to kilometers on Garmin 405
Touch MENU then touch SETTINGS then touch SYSTEM. This gives you the option of STATUTE or METRIC. Select METRIC and it will change from miles to kilometres
Sep 06, 2010 | Garmin Forerunner 405 GPS Receiver
May 17, 2010 | Garmin Forerunner 305 GPS Receiver
How do I change my garmin forerunner 205 from miles to kilometers
  1. Select Settings
  2. Select General
  3. Select Units
Jun 21, 2009 | Garmin Forerunner 305 GPS Receiver
Changing from Km to miles for my default settings
Follow this link:
http://www8.garmin.com/manuals/Forerunner50_OwnersManual.pdf
Read the chapter TRAINING SETTINGS.
Rate, please.
Mar 28, 2009 | Garmin Forerunner 50
GPS Logo
376 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
