How do you stop incomming repeat faxes
We have a company the has sent a fax up unitl now we have 25 copies how do we stop them comming to us no other faxes can get through to us we have a philips magic 5 series fax machine
    Genius:
  • 2,120 Answers
The sender has to be told to stop THEIR fax machine. Your fax machine is OK
Posted on Jan 24, 2009
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
On the m9516 what is the fax switch on and off used for?
The Fax Switch
The Fax Switch feature allows you to have two telephone numbers on one incoming line.
There is one telephone number for the line and another telephone number for a Fax Switch peripheral (e.g. fax machine).
To use the Fax Switch, you must subscribe to your telephone company for Distinctive Ringing†. The telephone company will then provide you with an additional telephone number (for your Fax Switch peripheral) which will have a slightly different ring. The 9516 will use the two ring types to determine whether an incoming call is for the telephone or the peripheral. The peripheral should be set to answer after three or more rings.
Note: If Long Distance Ringing† is available in your area, long distance calls will be sent to the Fax Switch peripheral. Also, you cannot use the Fax Switch feature and the Special Greeting feature at the same time. The 9516 must be configured so the Fax Switch peripheral is connected to pins 3 and 4 of jack number 2. See Connecting an optional fax machine or modem on
page 4 for more information.
Note:
If you subscribe to your telephone company for Call Waiting services, your Fax Switch peripheral may lose data or get disconnected if someone calls while your fax is receiving data. We recommend that you do not subscribe to the Call Waiting service from your telephone company if you are using the Fax Switch feature.
Jan 30, 2009 | NorStar Meridian M9516 Phone w/ Digital...
Phone won't go into voicemail, only fax mode
Your cable company is correct. Your printer is set to the phone/fax mode which allows the machine to be act as a phone or fax. It can tell the difference between an incoming voice call and an incoming fax. You should set your printer to Fax Only. Here's how:
  1. Push the menu button
  2. Press 0 (zero)
  3. Press 1 (one)
  4. The display should now show fax only.
  5. Press Ok.
To review what we did:
We set your printer to only recognize faxes when they are sent. Voice calls will now go through to your voice mail, if you do not answer.
If my assistance has been to your satisfaction, please rate my service. Thank you for using Fixya.com
Jan 24, 2009 | Brother Multi-Function Center MFC-240C...
Lexmark x7170. Ran out of ink during incoming fax. How can I retrieve the missed fax.
You can't ,once it exits the machine the fax is completed. If you print out a journal you might be able to tell who sent it.
Jan 06, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Have Lexmark X9350 All in one - Need to block incoming junk faxes
You can find these instructions on page 140 of the User's Guide. The English User's Guide is here: http://images.lexmark.com/publications/pdfs/2007/9300/v1116690_en.pdf
If you have Caller ID, you can block faxes sent from specific numbers and/or all faxes which do not include a Caller ID number.
To turn on the Block List feature:
  1. From the control panel, press up arrow or down arrow repeatedly until Fax is highlighted.
  2. Press select (checkmark).
  3. Press up arrow or down arrow repeatedly until the Fax Setup submenu is highlighted.
  4. Press select (checkmark).
  5. Press up arrow or down arrow repeatedly until the Fax Blocking submenu is highlighted.
  6. Press select (checkmark).
  7. Press up arrow or down arrow repeatedly until you reach the Block List menu item.
  8. Press left arrow or right arrow repeatedly until On appears.
  9. Press left curved arrow to save and exit.
To add each fax number you want to block:
  7. Press up arrow or down arrow repeatedly until you reach Blocked Fax Add Entry.
  8. Press select (checkmark).
  9. Use the keypad numbers to enter the name of the person associated with the fax number in the Name field.
  10. Press down arrow once.
  11. Use the keypad numbers to enter the fax number in the Fax Number field.
  12. Press left curved arrow to save and exit.
To block faxes sent from an unidentified number (a number with no Caller ID):
  7. Press up arrow or down arrow repeatedly until you reach the Block No-ID menu item.
  8. Press up left arrow or right arrow repeatedly until On appears.
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
164 people viewed this question
jasbo
jasbo
