Question about Vizio GV42L 42 in. LCD Television
Toshiba 19inch lcd tv green line down screen
This set is one year and three months old. Is it pixel failure and can it be repaired. Thanks
    President:
  • 2,992 Answers
A solid line down or across the screen is due to problems in the display itself. Unfortunately, there's no way to repair it because the bad circuitry is integrated into the display. The only cure is display replacement.
Not the solution you want, but that's how it is. (With the huge number of transistors that are part of the display, it's actually amazing there are as few failures as there are.)
Posted on Jan 22, 2009
Horizontal Green Lines On Screen. No Picture Visible. Problem is intermitent.
Are you certain of the connection? Sometimes the connector becomes loose or otherwise loses integrity. Maybe it's the cable (HDMI, right?)--or both the TV's connector and that. They may become worn.
Be careful with your LCD screen--they are more delicate than most people realize.....
Dec 16, 2013 | Toshiba Regza 52XV645U LCD TV
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
For past 6 Months The scren was bowing Horizontally and now it has sever ghosting.. What to do this TV is about 8 years old Model Number WS-65807
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 24, 2010 | Mitsubishi WS-65807 65" Rear Projection...
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Jan 19, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Red and green stripes (1" wide) running down the screen. Started with one red, now a green and another red. The stripes come and go at times, but most of the time they are present.
I hate to be the bearer of bad news but this is actually one of those known and predicted issues with LCD televisions. What these are called are "dead" lines of resolution aka dead pixels aka frozen pixels.
This is one of the flaws of LCD televisions, there is a completely random, unpredictable fail rate of LCD pixels in all panels, the likeliness of failed pixels varies depending on the quality of the panels used in the TV.
There really isn't a resolution to make them go away, if they are simply frozen, usually a light (VERY LIGHT) tapping of the screen at the top and bottom points of the line will refresh the pixels. If they are coming and going more often, it means that the panel is weak or malfunctioning in those areas and you need a new panel in the TV. Unfortunately it's quite an expensive repair, running at least $400 USD, if you are within warranty period (usually only 3 months for dead lines of resolution.. but it varies up to 12 months depending on the manufacturer) I would suggest calling Vizio and inquiring about a replacement TV. They generally won't allow a repair as it costs them less to simply give you a new unit all together.
My apologies for your bad luck!
Dec 09, 2009 | Vizio 42 in. LCD TV
I have a 54" Toshiba Regza LCD tv that has 2 pencil thin lines running up/down about 3"s from either side. The tv is about 1 year old with 1200-1500 hrs on it. Any idea what is wrong?
Maybe- The individual pixels on LCD displays are controlled by turning them on and off in an X-Y matrix. This matrix is scanned at a speed fast enough so the eye can't notice the action of the pixels so not all pixels are on simultaneously. The kind of failure you describe can be caused by the failure of two vertical drivers that are not being turned on and off any more.
In some sets, the driver chips are part of the display itself, meaning that a failure of one (or more) of the ICs may require a replacement of the entire display panel, a very costly repair. The ICs are small and have very close pin (contact) spacing, are placed in manufacturing by robots and generally, only specially equipped and steady-handed techs can replace these by hand.
Nov 26, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Failed Samsung 40" TV
sorry to gave u a bad news bad the color card is the all panel , tell me the model # and i would check how musch is the parts
Mar 15, 2009 | Samsung HCL4715W 47" Rear Projection...
No power to set - yellow light blinks
If your set is 6 months old, I would suggest to have it repair under manufacturers warranty. All the electronics devices have 1 year warranty.
The failure you have with your LCD is the power supply not working properly.
Let me know if you need further assistance.
Jun 12, 2008 | Toshiba 26LV47 26 in. LCD TV/DVD Combo
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Vizio GV42L 42 in. LCD Television Logo
1,098 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
