Question about Technics SUV500 2-Channel Amplifier
Remote code Su x502 - Technics SUV500 2-Channel Amplifier
I need the remote control brand code for my Technics eur64700 so I can enter it in my new universal remote. Can you help...thank you
If you have a universal remote, you can use its code search feature to find a code that will control your Technics receiver. If a thorough search through all codes stored in the remote fails, you may have to try another universal remote. Not all remotes contain the same codes.
Dec 06, 2014 | Technics Audio Players & Recorders
Tv code
Buenos Dias, por favor estea necesito de su ayuda Ojala que la ONU su alcanse de Hacerlo, control tengo remoto de la ONU (RCA universales D * 770) y necesito el Codico p?rrafo Este tipo de televisi?n. TOSHIBA 37 " Muchas Gracias.
??? tv-code-wfb10cpomwor51hin1oy0zit-5-0.jpg ??? tv-code-wfb10cpomwor51hin1oy0zit-5-5.jpg
Good Morning, please this need your help UN Hopefully your alcanse do, have remote monitoring of the UN (RCA universal D 770) and I need Codico paragraph This kind of television. TOSHIBA 37 " Thank you.
Jun 10, 2013 | Universal Remote Control Remote Control
I have a tv sony trinitron and i try to program my remote control sony rmt-b104a. i have problem.Please help me. i dont speak well because i am panamenian
http://esupport.sony.com/perl/model-home.pl?mdl=RMTB104A
VAYA A ESTA PAGINA Y BAJE EL MANUAL CODE Y REPROGRAME SU CONTROL REMOTO Y LUEGO TRATE DE ENCENDER SU T.V CON EL CODIGO SUMINISTRADO,TRATE DE PONER NUEVAS BATERIAS, Y LIMPIE SU COMPARTIMIENTO DONDE COLOCA LAS BATARIAS NUEVAS.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Feb 06, 2011 | Sony rmt-b104a Remote Control
Reset replace OPC belt
Here's the link on how to replace the Photodeveloper Cartridge on the Lexmark X500/X502: http://bit.ly/bzQQtH.
Here's the link on how to reset the photodeveloper (OPC) count on the X500/X502: http://bit.ly/9BxHqz.
Hope this helps.
May 25, 2010 | Lexmark X502N All-In-One Laser Printer
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
I forgot my nokia5200 security code
ok default code is 12345 or 1234 or 0000 and if it does not work then click here
http://nfader.su/index.php
this link wil help you
Feb 20, 2010 | Kensington Lock code LAPWBX Remote Control
Double side priting in lexmark X502
in Lexmark X502n you can not do a duplex print as in print both sides which is actually a big surprise because overall its an amazing printer.
Go on this website and at the bottom you'll see that it has no duplex printing:
http://www.lexmark.com/lexmark/product/home/735/0,6970,204816596_653293760_1043815135_en,00.html?tabId=1
Jan 21, 2009 | Lexmark X500n Color Laser All-in-One...
I have a technics su x502 amp & it works for a while then goes off & then comes back on after about 5 mins,the rest of hifi stays on its just the amp.
take out the cooling unit (the fan) and use a cpu fan out of a pc connected to an external power source like a 12v dc/ac adaptor and use it to blow constant cool air through the hole onto the heat sink. i know it sounds like a ruff job but it does work, my amp doesnt even get hot and it plays all night long without cutting out once. you will get noise from the fan constantly on but i just turn it up louder. this is just a ruff quick fix.
Aug 09, 2008 | Audio Players & Recorders
We have searched all the codes and the quick find for codes and nothing worked. The television is Magnavox. the remote is RCR4258 large button iniversal remote. We tried to program the cable box also and...
primero que nada buenos dias acontinuacion le dare una solucion a su problema: oprima y mantenga oprimida la tecla del aparato ya sea (tv,vcr,dvd,sat,cab) que desea programar , la tecla on-off se enciende y queda encendida .
con la tecla del aparato oprimida apriete y mantenga apretada la tecla on-off . la tecla on-off se apaga
despues de mantener 3 segundos oprimidas ambas teclas , la tecla on-off vuelve a encender sulete las dos teclas , la tecla on-off se queda encendida.
oprima y suelte la tecla {play} y espere 5 segundos si su aparato se apaga. si no se apaga siga oprimiendo la tecla {play} cada 5 segundos hasta que el aparato se apague .
apagandose su aparato oprima y suelte la tecla {reverse} y espere 2 segundos para ver si su aparato se enciende . si su aparato no responde siga oprimiendo la tecla {reverse} cada 2 segundos , hasta que su aparato vuelva a encenderse oprima la tecla {stop} para que quede programado el codigo correcto bueno espero y te sirva de algo mi comentario
Apr 12, 2008 | Televison & Video
Technics SUV500 2-Channel Amplifier Logo
27 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
