Question about ASUS UL30A-X5K Notebook
Asus ul30a-x5 Fan making noise - ASUS UL30A-X5K Notebook
Replace fan on gigabyte u2442
These worked great on my u2442f. You will need to order 2 of them:
http://www.aliexpress.com/item/Free-shipping-DC-5V-0-29A-Cooling-Fan-For-ASUS-Eee-PC-UL30V-UL30A-1201T-1201N/1859310048.html
Check out some youtube videos on opening up the unit; hidden screws under the gripper pads, etc. The fans are easy to remove and install, simple screws and a cable. But, I think one side did require unseating another cable to get to the fan.
It can be done!
Oct 09, 2013 | Gigabyte U2442 [U2442N-CF1]
Webcam not working
make sure you have the driver installed and working check in Device Manager to see if its present, or may be not working properly.
Mar 16, 2013 | ASUS UL30A-X5K Notebook
CANT WORK MY HAS KEY
any key that is listed on the top of another key press and hold down the shift key then press that specific key #@&%$
Feb 17, 2013 | ASUS (UL30A-A1) PC Notebook
My ASUS UL30A wont start up and the mouse pointer is thee only thing I see on a black screen
GO INTO BIOS SEE IF YOUR HARD DRIVE IS SHOWING UP IF NOT FAILURE . ALSO UNPLU IT TAKE BATTERYS OY AND RAM LET IT SET FOR A COUPLE HOURS PUT RAM NACK IN BATTERY AND PLUG IT IN AND TRY IT. BUT IF NO HARD DRIVE IS SHOWUNG IT IS SHOT.
Jan 07, 2013 | ASUS UL30A-X5K Notebook
The problemm is my ASUS UL30A WONT START UP
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Microphone is not working ASUS UL30a
Win 7 - Start > Control Panel > Hardware and Sound > Manage Audio Device> Sound > Microphone >Properties > Level. Make sure the microphone is not muted as well.
Oct 11, 2012 | ASUS (UL30A-A1) PC Notebook
Asus ul30a scroll not working
Visit the link to view detailed information on troubleshooting the scrolling feature.
Scroll
May 27, 2012 | ASUS Computers & Internet
My asus ul30a shuts down when I pick it up or move the screen
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 08, 2011 | ASUS UL30A X7 1.3 GHz 320GB 13.3 inch...
I bougth the Asus ul30a cople of weeks ago for repair .It had a broken screen now it's fixed but finally I find it has got bios password on it and I can do nothing with.Have no contact with previous...
According to ASUS support forum: http://vip.asus.com/forum/view.aspx?id=20080529004809218&board_id=3&model=A8Sc&page=1&SLanguage=en-us
Unlike desktop BIOS, you can't just remove the battery or move a jumper to reset ASUS notebook password.
What sounds to me like the most feasible choice would be: contact asus and prove you are the legal owner of the notebook and they can supply you with a "mastercode" specific to your laptop and serial number to unlock the bios.
May 08, 2011 | ASUS UL30A-X5K Notebook
My power steering makes loud noise 2001 x5 3.0l
one of two problems p/s fan belt is getting old or fluid to low the fluid filler will be down the left or right side of the eng 1/2 way from the front to back it will have black cap
Jan 07, 2009 | 2005 BMW X5
ASUS UL30A-X5K Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
