Question about ASUS Eee PC 900HA Notebook
Laptop asus u35jc power locked and blinking - ASUS Eee PC 900HA Notebook
Not working my asus after rebooting
can you describe what happened..is it showing any led's blinking when the power button is pressed?..then it's probabily a loose contact to your monitor..else if no led's are blinking then there might be some serious problem..search for any local asus service center
Mar 29, 2014 | ASUS U1F (14231588992)
Boot from usb
Set the boot option to USB first.
Feb 27, 2014 | ASUS Computer International U35jc A1 133...
Asus 1015bx black screen problem
would you please be a bit more specific about the symptoms? Like beeps? or blinking caps lock or num lock?
Nov 27, 2013 | ASUS Eee PC 1005HA-PU1X-BK Netbook
The battery led blinking red/green
Disconnect power cord. Please take out the battery. Hold down power button for a minute and then connect only power cord. Restart it again.
Jun 24, 2013 | ASUS Computers & Internet
Laptop battery broken?
i presume that your laptop is still working on wall power socket and since the battery is broken it does not run on battery
if that is the case then your laptop lamp which indicates charging is lit red and i recall that you need to have a new battery
hope this helps
Aug 29, 2012 | Sony Computers & Internet
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
Hey. i have a compaq CQ61 notebook and am having troubles turning it on. Whilst using it casually e.g. the internet and powerpoint it just shut off. When plugged in to the power supply, the light glows on...
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | Compaq Presario Notebook
Hp compaq powering and nog display what do i do to
May 21, 2010 | HP Pavilion dv6000z Notebook
BOOTING MY LAPTOP
try replacing the memory mods. It dosen't sound like a battery issue
Jun 01, 2008 | ASUS Computers & Internet
ASUS Eee PC 900HA Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
