My dvd player keeps reading "Bad Disc" when I know the disc's are ok. It reads this for anything I put in. Is she dead?
  • Anonymous May 08, 2009
    I have exactly the same issue. I have bought brand new discs which will work on my pc but the DVD player won't read them. In fact it doesn't seem to read any!
  • 50 Answers
First turn off your dvd player and then open it, to open it you should unlock the screws by using screw driver, after you open it, you can see a lens on it, clean it with a soft cotton or a clean cloth. then turn on your dvd and insert a disk, see if it plays a disk, If not, you must adjust the trimmer at the lower portion of the lens, it is connected to a small circuit that is connected also to the lens, you should turn it clockwise but just a little bit.turn on your dvd and cover the lens with both fingers, be sure not to touch the lens, if you cover it, be sure also that you can see the lens, and look closely if it emits a thin red light, which is the color of the laser, if it emits, then your dvd is now ok. turn off your dvd, put the cover case back to its proper place
Good luck, have a nice day ahead
Posted on Jan 22, 2009
Player reads DVD as bad
Are you using the correct format disc.If you are playing a blu ray disc in a non blu ray player the player will not read the disc
Jan 02, 2018 | Durabrand Audio Players & Recorders
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Bush portable DVD player will not load my disc
Hello
Just put in an audio CD disc or an MP3 disc, and see whether it reads them or not. If the player can read these discs, and only refuses to read DVD discs, make sure that the laser pickup unit of it is faulty, and should be replaced with same type and number. If none of them reads, there are two possibilities, the first one is of laser pickup disc itself and the second one is the strip wire [a flat flexible cable connected between laser pickup unit and the mainboard of the player] is faulty. First replace the strip wire. If it helps you, it's OK. If not replace the laser pickup unit also. The strip wire can be bought from most of the electronic spare part shops at your town. When buying laser pickup unit, its number must be noted, and exact replacement should be done. Otherwise, it won't match with the main board. OK.
Nov 08, 2011 | Televison & Video
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
I place the dvd in the holder, and it closes, but does not play. It says loading and then nothing. please help.
Tries the tv DVD player,play it with many other DVD discs too?Some the disc u trying to play it might just be bad like the reading shinning laser surfaces are scratches,smushes or grims and dirts on the disc reading surfaces?Tries washes the DVD disc,with some dish washing liquid,dries it with a cloth wait like two mins.Try the DVD disc again.If it have problems,but all DVD discs or with many other DVD discs too?Tries websites like Ebay.com or Amazon.com buy a Disc cleaning kit put Disc in the DVD player to play it have 50/50 chances to clean the DVD player laser eye reader.If not more like the DVD player laser eye it is dead.Tv still work fine?Don't take the tv aparts,tries to clean it laser eye manally,because,if u putting tv back together again might causes tv problems too.Just buy a DVD player unit plug it in the tv and play ur DVD Discs.DVD player extenal unit it very cheap these day.Don't take chances,like take ur tv aparts.
Feb 12, 2011 | Naxa Electronics NX-542 13 in. Portable TV
Can not read dvd format
The player uses a different laser to read dvd's in respect to cd's. Either there's dust on the laser (or lens) and it needs cleaning or the dvd laser unit is busted - it can't be fixed, junk it and buy a new one.
Nov 30, 2009 | Hyundai Televison & Video
My DVD player / recorder keeps kicking out the discs I put in. It won't even read them. the screen says close and the tray comes back out almost immediatly. Now it's gotten so bad that the tray won't come...
How old is your DVD recorder/player?
It sounds like it needs a service!
The usual problem with DVD players/recorders not reading discs is that the laser output is starting to fail - and consequently the laser light emitted is insufficient for the system to "read" through the minute "holes" in the disc.
It's possible to have the laser replaced, but this would cost you at least £50, depending on where you live.
Initially, you could try buying (or borrowing) a laser cleaning disc. These cost around £3 to £5 depending on where you buy & live, and have a small brush on the lower side of the disc. Insert this into your player and run the disc for a couple of minutes. If there are any dust particles that have been blocking the light output from your laser head, then this may remove it and might solve the problem.
If this fails, then it seems likely that the laser head is not producing enough output and would have to be replaced with a new one.
Also, you could try playing a CD on your DVD player as these discs contain far less information than a video disc (DVD) and the laser head may be able to cope with this.
If the CD plays ok, then you will know that the reason why it won't play DVD's is the light output has started to fade due to the age or excess use of your system.
Nov 17, 2009 | Sony Televison & Video
I get the message "bad disc" with every disc I put in the player.
ok best bet is that your laser (what reads the discs) in your laptop is dirty, use a cd/dvd cleaning disc to clean the laser, can buy them from most computing, music shops
Jun 29, 2009 | Polaroid Portable DVD Player PDM-0822BD
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
