Question about De'Longhi Nespresso Lattissima Plus Espresso/Cappuccino Machine: Nespresso Latissima Plus Espresso/Cappuccino Machine Silver
Nespresso latissima milk comes too cold
Milk is not hot enough to make a hot coffe, is it possible to make milk come hotter?
I have a nespresso Latissima with auto milk frothier & the plastic tube which draws the milk tastes & smells like curdled milk. I can taste it in the coffee as well.
Try running 1/5th vinegar and 4/5 water through the frothing device. This will clean out any gunk that might have clogged the interior
Oct 16, 2013 | Nespresso Coffee Makers & Espresso...
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aug 26, 2012 | Coffee Makers & Espresso Machines
The frother doesn't froth. I start with cold milk fill it to the hot froth line and push. The red circle lights up and whirls around, but when it stops there is no froth
I have tried tilting mine slightly, just a 20c peice under one edge of the base put enough of a lean on it to make the milk froth. Shouldn't have to do this, I know. I am having similar issues becasue I don't think I should have to alter the unit. Mine is 2 weeks old.
Feb 15, 2011 | Nespresso Aeroccino Automatic Milk Frother
My Nespresso milk frother did not come with instructions. Is there some way to froth but not heat the milk?
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Jan 25, 2010 | Nespresso Aeroccino Automatic Milk Frother
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Lost my Nespresso Aeroccino Milk Frother Hot Milk Whisk
Call Nespresso customer service at 800-562-1465. Replacement set of 2 wisks were $2.95 + shipping
Feb 02, 2009 | Nespresso Aeroccino Automatic Milk Frother
De'Longhi Nespresso Lattissima Plus Espresso/Cappuccino Machine: Nespresso Latissima Plus Espresso/Cappuccino Machine Silver Logo
82 people viewed this question
Top De'Longhi Coffee Makers & Espresso Machines Experts
ray gallant
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
