Question about Kenmore Sewing Machines
Kenmore 158.904 feed dog knob won't lower the feed dogs, it's frozen in the 'up' position.
  • 29 Answers
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
Posted on Jul 14, 2007
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
  • 19 Answers
SOURCE: My kenmore 385 won't feed fabric
hi there check feed dogs are up not down mary h
e
Posted on Dec 30, 2008
  • 2976 Answers
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Posted on Jan 03, 2009
Feed dogs lowered can't raise material not feeding thru
Is your machine mechanical? If so, sounds like the feed dogs are stuck in the lowered position. Needs good cleaning and oiling.
Perhaps this will help:
The feed dog knob won turn don think anything is broken haven used the...
Dec 30, 2015 | Sewing Machines
I have a singer 543 the feed dogs won't move.
I suggest getting out your manual and looking up lower and raising the feed dogs. When the feed dogs are lowered they don't move. You could have lowered them without realising it.
Mar 18, 2013 | Sewing Machines
Material won't feed through on kenmore 17600 sewing machine
Take out the material, take off the foot and needle. Stick your finger on the feed dogs and hand turn the hand wheel like sewing. Does the feed dog come slightly above the surface of the needle plate? If it does.... tighten the presser foot tension.
If it doesn't locate the switch that drops the feed dog. Make sure it's in up position.
If neither of those solutions work. Remove the needle plate and see if the feed dog or mechanism that runs it is broken
Good luck
Nov 10, 2012 | Sewing Machines
Feed dogs not moving properly
it's very possible that the feed dogs are out of time & the machine would have to be serviced at a sewing machine repair shop
Mar 05, 2012 | Kenmore Sewing Machines
I put the feed dogs down and now they won't go back up, what do I do now?
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Feb 11, 2012 | Baby Lock Ellure
CI just got my sewing maching six month ago and now for the first time it giving me problem . whenever im sewing the fabric won't move please please !!! help me to fix the problem.
in the needle plate area you'll find the feed dogs, they move the fabric forward as you sew, they should be up to sew . most sewing machine have a lever or knob that can be moved to change the feed dog position, unless then knob is broken
Aug 04, 2011 | Sewing Machines
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Feed Dogs Kenmore 158.19802
I think the feed dog lever needs to be positioned on the right.
Sep 15, 2008 | Sewing Machines
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Feed dog is stuck
May 07, 2007 | Singer 2662
Sewing Machines Logo
20 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
