Question about HP Bestec ATX-1956D 200w HP Part No 0950-4106 (ATX1956D) Power Supply
My part not turn on wt' can i do
I connect it b't not turn on wt' can be the problem?
  • 63 Answers
Not worth wasting time diagnosing/repairing a bestec...
afraid to say purchase a new part...
Matt
Posted on Jan 22, 2009
Switch to switch colour code
Cat 5/6 cable connections - straight thru both ends the same.
cross over cable - one end type A other type B
TYPE A
wt-or
or wt
wt grn
blu wt
wt blu
grn wt
wt brn
brn wt
TYPE B
wt grn
gn wt
wt or
blu wt
wt blu
cr wt
wt brn
brn wt
Color Table
wt - white
or - orange
blu - blue
grn - greeen
brn - brown
wt blu = primary color is white with a blue stripe color
blu wt is primary color is blue with a white stripe
Feb 09, 2013 | PC Connection Cross-Over Cable (363003X)
Walbro wt-141 changeover to wt-629
If the carb has two connections then it is designed to work with a primer bulb, the fuel inlet will be nearest to the pump cover, the alluminium cover held with a single central screw, you can either get the correct carb for the machine or use a short rubber tube with a blank in the end ti close it off.
Feb 02, 2013 | Poulan Weedeater Carburetor - Walbro...
I need that
http://www.microsoftstore.com/store/msstore/html/pbPage.Office_Compare_Editions?WT.mc_id=pointitsem_US_Google_5-OfficeSpecial_generic&wt.term=microsoft%20office&wt.campaign=*5+-+Office+%28Special+Budget%29+best+kws&wt.content=EhqYakCB&wt.source=google&wt.medium=cpc&WT.srch=1
Aug 01, 2011 | Microsoft Office Professional 2007 Full...
Need to now what kind of oil to use on my front fork,and dont want to have to get it at the harley shop. Also can marker lights be used as turn signals? I dont like the look of the original turn signals...
Try using PJ1 fork oil. It works well and you can buy it at most bikes shops other than the Harley shop or you can order it. Most of the time, 30 wt. oil is equivalent to Harley's "Type E" oil. if it's too stiff for you, drain and drop back to 20 wt. Some of the bike shops that specialize in off road stuff might have a 25 wt. and they go all the way down to 5 wt.
Now, you didn't tell me what year model bike you have. If you have a bike made after about 1992 or so, it probably has a turn signal canceling unit on it unless the previous owner took it off. If so, you are pretty well stuck with running either stock lights or at least a turn signal light that uses an 1157 bulb. If you go with the small bulb lights or LED's, you'll change the resistance that the turn signal canceling unit is looking for and it won't work. Much like when you connect a trailer to a truck with a standard flasher unit in it and the turn signals blink real fast.
You can get a system that will work but you'll have to go aftermarket. A lot of the systems are called "load equalizers" and are designed to work with the original flasher unit. Some systems are completely independent. They're made by Badlands and a few others. Check their site and maybe see what Custom Chrome has to offer.
Good Luck
Steve
Mar 27, 2011 | Harley Davidson FXDWG Dyna Wide Glide...
How to install microsoftoffice
you can download MS office from here http://emea.microsoftstore.com/UK/en-GB/Microsoft/Office/Suites-2010?WT.mc_id=pointitsem_office_download&WT.srch=1&WT.term=download+msoffice&WT.campaign=6072&WT.source=google&WT.medium=cpc&WT.content=623230491&cshift_ck=2133261701cs623230491&WT.srch=1&tid=623230491 once purchased you will get a key and then you can run the install program and it will install MS office
OR
if these a recent purchased PC - then you will have a demo version that once you buy the key you can use
Sep 28, 2010 | Lenovo G550 156 250GB Notebook
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Computers & Internet Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
