Question about DeLonghi Nespresso EN660 Espresso Machine
My nespresso lattisma not frothing milk properly, milk is coming out with bubbles and air only
SOURCE: EAM3500S will not froth milk ?
First, check to see if it will pump out steam without a ton of water. If it doesn't, don't use it.
Now, skim milk is terrible for it, the bubbles are too dry and flavorless. Use 2% milk or half-and-half. It should be cold (very cold). I put mine in the freezer in a steel frothing container for 5-10 minutes before use. Just barely submerge the wand (about .25") and turn on the pressure. It should sound like tearing paper (not like blowing bubbles through a straw). Do this until volume increases to around double (if you have a frothing thermometer, it should be around 100 degrees F). Now submerge the wand farther and tilt the cup to create swirling (this is called stretching & sweetens the milk). This should be done until the temperature is around 140-160 degrees F. Done.
If your machine is no good for steam, there's another way: Put milk into a steel cooking pot (I use a saucier for large groups) and put it in the freezer. When very cold (ice forming) put on stove. Whisk briskly while heating up on medium-high. It will create fine foam & stretch the milk at the same time. The bubbles will start big, but become finer as time goes by. I test by stocking my finger in & going until it feels nearly scalding & remove from heat. Just use a ladle for he milk & a spoon for the foam.
Posted on May 03, 2009
SOURCE: Delonghi Magnifica Coffee Maker the milk is not
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Posted on Oct 08, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
SOURCE: There is no milk coming out of the frothing part
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
Posted on Jun 21, 2010
SOURCE: Milk frothing problem on a Magnifica 3500
Had the same prolem replaced the coupling where the jug clips in. Item 111 - part number 5532123200 coupling. If your not technically experienced then you may need to take it to a service agent. Had to fairly well dismantle machine to complete repair.
Posted on Jul 02, 2010
My nespresso milk frother red light doesn't come on, it is staying blue
I found that when I switched milks from whole to two percent organic it stopped frothing. When I tried a friend's creamer it worked again.
Oct 12, 2013 | Nespresso Aeroccino Automatic Milk Frother
Nespresso milk frother instructions
I had the same problem. From reading various sites it is clearly a common problem. Most suggest phoning Nespresso to get it replaced but one website suggested turning the machine upside down. Not the base, just the aeroccino. Leave it like this overnight and it resets itself. I don't understand how that works but I tried it as it was a weekend and wasn't going to be able to call the helpline till Monday. And it worked! I now have proper froth again. Other suggestions seem to be try never to get the underneath wet (I think leaving it upside down ensures this area dries out completely), don't leave it on the base when not using and certainly don't leave it on.
May 19, 2013 | Nespresso Aeroccino Automatic Milk Frother
My nespresso aeroccino automatic milk frother is spinning and heating up but not frothing milk
I found that switching to a different milk solved my issue. It worked well with whole milk, but when I used Trader Joe's two percent organic it would not froth after .multiple tries. I borrowed a neighbor's creamer and it worked again.
Oct 13, 2012 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aug 26, 2012 | Coffee Makers & Espresso Machines
My nespresso machine won't froth the milk
Brand of milk definitely matters... Here in Canada I used Sealtest 1% when I first used it and the froth was thick light and luxurious. Then one week picked up Neilsen 1% and found it produced absolutely ZERO froth. Back to Sealtest...back to froth. Milk brand matters....but don't know why.
Jan 14, 2012 | Nespresso Aeroccino Automatic Milk Frother
My Nespresso milk frother did not come with instructions. Is there some way to froth but not heat the milk?
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Jan 25, 2010 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Apr 01, 2009 | Krups XP 4050 Espresso Machine
DeLonghi Nespresso EN660 Espresso Machine Logo
26 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
