Question about Microsoft Windows XP Professional
Problem with botting my system......plese reply
When i boot every time there willl be a wizard which takes me to a operating system selection though i hav only one OS ie windows xp
  • 81 Answers
The solution for this issue would be...
In order to get this issue fixed... What needs to be done is as follows...
1) Right click on My Computer...
2) Then in the drop down menu... Left Click on Properties....
3) Then you will get the system properties window...
4) In System Properties Window... Go to the Advanced Tab...
5) Under Advanced Tab Click On Startup & Recovery Tab.
6) Under Startup & Recovery Uncheck the option's which says time to display OS 30 seconds.. Uncheck both the options
Posted on Jan 22, 2009
D3123 wont boot
Use System Restore
To use System Restore, first restart the computer by pressing[Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the singlebeep, press [F8] to display the Windows Advanced Options menu. Now, select theSafe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Startbutton, access the All Programs ' Accessories ' System Tools menu, and selectSystem Restore. Because you're running in Safe mode, the only option on theopening screen of the System Restore wizard is Restore My Computer To AnEarlier Time, and it's selected by default, so just click Next. Then, followalong with the wizard to select a restore point and begin the restoration procedure.
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwantted files and fix registry and windows errors.
Jan 04, 2012 | eMachines D3123 Desktop Computer With AMD...
D3123 windows wont boot
Use System Restore:
Windows wont boot
Hi Rajib Chakraborty,
When posting issues try to be a details as possible this help to solve the problem more quickly and you problem answered more quickly.
Below are some step you can take to try to boot into windows if this fail, please provide more details to problem you are having.
1. Boot from Last Known Good Configuration
If the PC is on first restart the computer by pressing[Ctrl][Alt][Delete].
When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
2. Use System restore
To use System Restore, first restart the computer by pressing[Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the singlebeep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs ' Accessories ' System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
Nov 11, 2011 | Microsoft Windows XP Professional
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
When i start my pc than come to windows than it willl restart automatcally how can fix this problem
Try to boot the pc in safe mode...
To boot in safe mode by pressing F8 key while switching on the system...
If it boots properly in safe mode then run the checkdisk command in your command prompt...
Click start goto run type "cmd" press enter ( without quotes )
and type " chkdsk c: /p " (without quotes) press enter...
do the same process for three to four times...
and restart your pc...
If still problem happens just reply me...
Thanks...
Sep 21, 2010 | AcerPower S285 PC Desktop
Problem while installing Windows 7 and Fedora Core 10
OK, FIRST, take off the fedora drive, and get that working first, Now, ADD the other drive, and configure that. You may have to pop your Windows,DVD in and do a Startup repair, after that then you can can select either one. Check this link out below it is a tutorial, of how to do what you want.
http://www.thpc.info/dual/win7/dualboot_win7+fedora11_grub_on_win7.html
Apr 15, 2010 | Compaq Presario 700 470024-192 Notebook
I disabled video card now my monitor is black. i can see the boot screen. i can hear my desktop when it loads. i tried safemode(it never loads in safemode)...last known workig....i still cant see anything.
Kindly repair or reinstall your Operating system. It has a file that has been corrupted. To avoid the damage become big try to repair it or reinstall the OS without reformatting or erasing the files save in your hard disk.
Kindly follow the steps below:
To repair/Reinstall your operating:
1. Insert your CD installer into your DVD/CD Rom then reboot your computer/Laptop.
2. Press F8 or F12 to enable boot sequence and display it in order to select the boot. Then select the DVD/CD Rom boot. Or Press Del to enter CMOS and set the boot configuration sequence and select the DVD/CD Rom as your priority to boot the system.
3. *** soon as message will display "Press any key to boot CD" then press any key to boot CD. Then wait for the CD to load all its components.
4. After loading all its components kindly follow the instructions givien by the installation wizard. Note that if you where ask by the installation wizard to press r to repair or enter kindly select enter then let the system detect the existing installation of OS in your system then it detects then press enter then kindly select "Repair" to repair the detected OS or Select "Don't make changes and make it intact" then enter to reinstall the OS without erasing the files save in your hard drive.
5. Kindly follow the instructions given by the installation wizard to finished the installation or repair of your system OS.
6. If you don't want to repair/reinstall by your self then you can contact a technician expert in computer to fix it for you.
If you need more assistance kindly reply to this post.
thank you
geo_jonas
Jul 30, 2009 | Acer Aspire™ T180 PC Desktop
Cant get on.keeps saying operating system not found.ihave windows xp.can you tell me what to do and why its doing that?Thanks
Do you have the original start up disc? If so use it. If not there is generally a button to use at start up that will get you to a screen where you can restore your computer to a previous date. The button is usually F10 or F11 or one of the f keys. Also make sure that you don't have a disk in one of the drives. Take everything out and try starting it up. Good luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
Boot Disks Required
Open my computer select A the floppy drive and do a right click and select boot disk
and enter
bye
Mar 24, 2009 | Computers & Internet
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
