Question about Video Game Consoles & Games
Trying to get started with the skylander giants game on wii, console will not read disc, any other game works fine, not sure what to do now
    Novelist:
  • 159 Answers
Check that it is the correct region format Eg: PAL or NTSC depending on country, If after you have checked this and it is correct then it could be a simple case of faulty media. To check if it is faulty media check the disk in anotherr Wii console if possible. If all else fails contact the store at which you bought it or the software company that has distributed or made the game. I hope this helps.
Posted on Jan 12, 2013
SOURCE: wii console
Did you try turning the disk over so the label shows on the opposite side. With the Wii you have to put them in upside down it seems.
Posted on Nov 30, 2007
frankgant
  • 250 Answers
SOURCE: Wii unable to read disc
One of two things has probably happened and is the case 9 out of 10 times. Your drive may have gone bad either due to a chip failure or a laser failure. It's also possible if the unit has gotten hot that the connection to the drive isn't making good connection anymore. This happens a lot. To fix it you would have to open the unit up. I don't recommend this if you have never worked on consoles or other electronics before. If the unit is under warrenty send it in for repair. Otherwise you would have to pay for the repairs. You can also sell the unit as broken on ebay and generally recover quite a lot of your money.
If you are good with repairs of electronics you may choose to open it up and do some troubleshooting. There are several places on the internet that outline how to open the wii and how to troubleshoot it's problems. If you decide to go this route you will void any warrenty you might have. However sometimes this is about the only solution people have without spending money for Nintendo to fix it.
Posted on Sep 12, 2008
  • 26 Answers
SOURCE: Wii console won't read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving Disc Read Error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the Problem Yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Feb 20, 2009
  • 32 Answers
SOURCE: The Wii will not read the disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Mar 04, 2009
SOURCE: downloading wii games & disc not recognised on wii
That's because you need a modchip inside your Wii, like Wiikey...
So you can play any Wii Game (Japan, PAL, US Games) or burned Wii Games...
Posted on Nov 29, 2009
How to play eu games on us wii
Most consoles are made with different coding between the US and internationally. Is you have a US Wii you cannot plat European games and vice versa.
May 13, 2014 | Activision Skylanders GIANTS Starter Kit...
Why my wii skylanders giants won't read cd
This will depend on a few things.
1. If sky landers is the only game that will not work then it is likely that it is scratched or damaged in a way that makes it difficult to read. You can buy special cleaner for your cd to help with this if the damage is moderate to minimal. Or use a home remedy like tubing a banana on the side to be read and wiping it all off with a microfiber cloth and giving it a quick rinse (never submerge) and drying. The banana fills in some of the scratches.
2. If you wii has a hard time reading any disc then you should buy a cleaning disc meant to go inside the wii and clean the reader. One designed for computers and CD players should work just fine.
Will not read disc
The disc is probably scratched, if it is I would recommend buying the game again. If not then see if any oher discs are not working if others are messing up as well then it may be an issue with the wii.
Apr 19, 2014 | Activision Skylanders GIANTS Starter Kit...
My skylader from spyro's adventure has an error, what do I do?
If you are getting an error stating A toy on the Portal of Power has a problem, follow these steps to reset your broken toy.
Skylanders SWAP Force
  1. With the toy on the Portal, select Pause.
  2. Select Skylander.
  3. Select Manage.
  4. Select Reset. If you are resetting a swappable toy, you must reset both the Top and the Bottom separately.
Skylanders Giants
  1. Keep the broken Skylanders toy on the Portal of Power and open the Pause Menu.
  2. Return to the Main Menu.
  3. Open Settings.
  4. Select General.
  5. Select Reset Broken Toys.
  6. Select Yes when you are asked to reset the Skylanders toy.
  7. Repeat Steps 5 and 6.
  8. Keep the reset Skylanders toy on the Portal of Power and start a game in Story Mode.
Your Skylanders toy will now work again.
If the screen turns black after returning to the game, try again starting with Step 1.
If the game won't load and you are only seeing an icon on the screen, remove the Skylanders toy from the Portal of Power, put it back on the portal, and try again starting with Step 1.
Jan 26, 2014 | Nintendo Skylanders Spyro’s Adventure...
My skylander on spyro's adventure has a problem, how do I fix it?
Try this :)
  3. Select Manage.
Skylanders Giants
  3. Open Settings.
  4. Select General.
I have just brought the skylanders giants wii starter pack,when I start the game and it asks for me to put a figure on the portal nothing happens
Are batteries in the portal, is it synced with the console. To sync remove battery cover and SD card cover on the Wii press the two red buttons at the same time they are now wirelessly connected.
Aug 11, 2013 | Skylanders Wii Gaints Starter pack
My wii console can't read my wii U skylander giants disc
I can only pray this is a joke question. Wii ISN'T wii U. That's whyit wont work. It's like putting a wii disc into a ps3.
Dec 01, 2012 | Activision Skylanders Giants Starter Pack...
Our wii console will not read any discs
Sent the console to Nintendo to be repaired.
Jun 24, 2009 | Nintendo Wii Console
"Unable to read disc" error happened today for the first time on my Wii. I positioned it horizontally and tapped on the top while it was reading a disc and it started the game. This temporary solution might bring you immediate, but probably not long lasting satisfaction.
Sep 12, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
87 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
