Question about IBM ThinkPad 600E 2645 Notebook
Hi this bhaskar here i have IBM think pad but in swiched on message is enter pass word
  • 1 more comment
  • ROD GANDY May 11, 2010
    need more discription on the problem
    NEED MORE INFORMATION
  • Randy Hough
    Randy Hough May 11, 2010
    Bios or windows password?
    What OS? (Windows xp,vista,etc...)
  • 1,602 Answers
I UNDERSTAND THE SYSTEM YOU HAVE HAS A BROKEN SWITCH,
WHAT IS OS, ANSWER IS OPERATING SYSTEM.
YOU HAVE LOST THE SETTING IN THE CMOS DUE TO A SHOCK, ITS BEEN DROPPED, THE BATTERIES ARE OLD AND NEED TO BE REPLACE.
*************CMOS ENTREE:******************************** FOLLOW INSTRUCTIONS ON SCREEN WHEN FIRST TURN ON MACHINE F 8-12
ONCE YOU PUSH THE F KEY A FEW TIMES OR UNTIL IT BEEPS AND IT MAY TAKE A WHILE TO GET THERE.
CTRL-ALT-ESC AT THE SAME TIME MAY TAKE A FEW MINUTES TO DUE IT.
SOME CMOS'S OUR SOFTWARE DRIVEN IBM AND MAC SYSTEMS.
SOME MAY REQUIRE ADMINSTRATION APPROVAL NAME AND PASSWORDS
THE JUMPER JUMPER LOCATED ON THE MOTERBOARD RESET SWITCH********** NOT THE RESET SWITCH FOR THE C/P REBOOT
THIS JUMPER WILL HAVE 3 JUMPER AND MOST OF THE TIME THE JUMPER ARE SET TO 1-2 AND TO RESET BOIS MOVE THE JUMPER TO 2-3 FOR A FEW SECONDS THAN PUT JUMPER BACK TO 1-2.
IF IT HAS THE CIRCLE ROUND DISC SHAPE BATTERY JUST REMOVE IT AND PUT IT BACK THE WAY YOU FOUND IT AND REBOOT THE COMPUTER.
***********IT WILL ALLOW YOU TO ENTER THE BOIS TO SET IT UP.***********************
IN THE CMOS KEEPS RECORDS, CDROM, DVDS, FLOPPIES, HARD DRIVE SIZE,TYPE ,MAKE, MODEL, IF IT FORMATED,OR NOT.
IN COMS HALF WAY DOWN IN CMOS AUTO FIND HARD DRIVE
OR
HARD DRIVE SETTING IF YOU KNOW THE TYPE 1-44 DRIVES
OPTION SETTING
PUT NUMBET LOCATED UNDERNIETH THE HARD DRIVE IN THE CASE MOST OF THE TIME IT IS ON TOP OF HARD DRIVE
LOOKING TYPE, MODEL #
LOOKING FOR THE FOLLOWING.
WRITE EACH ONE DOWN INSIDE THE CASE SO IF IT HAPPENS AGAIN YOU KNOW WHAT TO DO AND HOW.
# OF CYLINDER 1024 AND UP
# OF HEADS 1-16
# OF SECTORS 1-63
DMA YES UNLESS YOU TOLD SOMETHING ELSE
LBA YES
TRANFER MODE ;STANDARD UNLESS YOU KNOW WHAT TO PUT
F10 TO SAVE
Y FOR YES
ENTER
REBOOT AND SAVE EVERYTHING TO CMOS
ROD
Posted on Feb 11, 2009
Sond device installer for ibm think pad type 1860 No 4 S/ NL9-KM 039 505
Get onlineand got to www.google.com In the google search box type: "IBMSupport" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.
May 08, 2012 | IBM Computers & Internet
Hi - I have an IBM Think Pad T43 and everytime I press the power button, it starts, but before the password screen appears, a warning box appears and states: services.exe - Application Error The...
Hi. You need to reinstal windows and drivers.
But if you have a backup use it. Is helping you to save your private data like a.. photo , music , movie , etc.
If you don`t have a backup.. hm.. try to enter in safe mode . if you can`t enter in safe mode just reinstall clean windows. Cheers. ! [Sorry for my bad EN.]
Jun 12, 2017 | IBM ThinkPad T42p Notebook
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
Where to purchase ?????
try this ebay auction number it is a power cord for think pad for may different models this might just work for you. good luck!
ebay auction Item number: 270343560573
Mar 29, 2009 | IBM ThinkPad Replacement Part
Locked screen
I found a page with a video, on how to open a padlock - I hope this is what you need, it looks easy.
3325d60.png plz let me know how you go - maybe I know of a safe we colud open...
/Teis
Jan 16, 2009 | IBM ThinkPad T20 2647 Notebook
Think pad 380ed will not start
161 &163 error messages indicate that the C-mos battery is dead and needs replaced.
Jul 11, 2008 | IBM ThinkPad 380ED
Locked screen
emove the CMOS battery, POP will be vanished right away. But after that, you have to enter BIOS to set the time/date, otherwise laptop won't boot.
if that doesnt work goto
http://www.passwordmethod.com/
Jan 02, 2008 | IBM ThinkPad T21 Notebook
IBM Think Pad T30
Off which thing u r talking about??? i cannot understand you question! Plz be clear about the questions so we can assist you!
Which software your lappy was running when you got the message? and which operating system you r using?
Dec 08, 2007 | IBM ThinkPad T30 2366 Notebook
ATI Graphics card
Try downloading new driver for the card from this link
http://ati.amd.com/support/driver.html
Oct 16, 2007 | IBM ThinkPad R32 2658 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
102 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
