Question about NetGear WGR614 Wireless Router
Need my password or key for wii consule
Wii consule needs password or key for connection to net
  • 55 Answers
You can find it out by looking at the router setup page:-
http://kbserver.netgear.com/products/WGR614.asp
Select your router model (v5,v4..) and look at the docs on the webpage.
You can login to your router by using one of these IP addresses http://192.168.0.1 or http://192.168.1.1 in your browser address bar.
You will see your network key under the wireless settings.
Hope this helps.
Posted on Jan 25, 2009
How to connect my Wii consule to a HDMI monitor,my Wii connection cable only has plugs I need a different connection cable
You need what is called a scan converter. It will allow you to input your cables (assuming RCA type) and come out the other side with HDMI.
May 10, 2016 | Nintendo Wii Console
Wii says needs update in order to connect with Wii Store which would allow me to download NetFlix Ap. It is connected to the net but I keep getting error message that says update could not go through. It...
Hi there!
There are two ways to connect your Wii to the internet; you can connect to your wireless network (if you have a wireless modem set up in your house), or you can connect using a wired connection directly to your modem.
If using a wired connection, you will need to purchase a Wii LAN adapter and connect that from your WII into your wired router.
Once you have figured out what connection type you will use (and if using a wired connection, purchased and connected your Wii LAN adapter) you will need to take the following steps:
FOR WIRELESS CONNECTION:
  • Turn on your Wii and click on the "Wii" button on the bottom left of the screen
  • Click on "Wii Settings"
  • Click on the arrow on the right side of the screen and select "Internet"
  • Select "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click on "Wireless Connection" and then "Search for an Access Point"
  • Select "OK" and the Wii will display all the wireless networks it finds.
  • Select the wireless network that is yours.
  • If it asks you to enter a password or key, then your wireless connection is password protected and you will need to enter the password that was setup to allow access to your network.
  • Select "OK," "Save Settings," and then "Yes."
  • Your Wii will test the connection and you should get a message saying connection was successful.
FOR WIRED CONNECTIONS:
  • Connect your Wii to the Wii LAN adapter and connect that to your modem or broadband adapter. Please not that you will need to unplug your modem for a few minutes to reset the connection and you will also need to unplug the connection to your computer when you want to connect your Wii to the internet.
  • Turn on your Wii and select the Wii icon on the bottom left
  • Click the arrow on the right side of the screen and select "Internet"
  • Click "Connection Settings"
  • Click "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click "Wired Connection"
  • Click "Ok"
  • Your Wii will now do a connection test
  • You should see a message saying the test was successful
Hope this helps!
Jul 06, 2011 | Nintendo Wii Console
I am trying to watch a movie on net flix, however everytime I tried to look for the internet service the following error comes up: Error code 51330 is unable to connect to the internet.
Hi there!
Error code 51330 on the Wii means that the password you entered into the Wii to set up your internet was entered incorrectly. You will need to go back into your internet connections settings menu on your Wii and enter the correct password/security key for your router. Please remember the security key is case sensitive.
Hope this helps!
Jul 05, 2011 | Nintendo Wii Console
Where do you find the ssid code to connect to the enternet with the wii
You will need the SSID and the network key/password (if you have one set up). The SSID is on the wireless router and is the network name. You may need the password also to access the net on the Wii.
Regards.
Apr 24, 2011 | Nintendo Wii Console
Internet will connect to my wii
if you need to connect your wii to the net click the wii button at the bottom left of your screen then click wii settings now click internet click on wireless and let it search for your wireless network once it has found it move the pointer to your network, if your network is protected it will ask for the security password or key , enter the key on the wii. then click ok. It will now test the connection. If it is successful it will inform you and probably ask if you want to perform a system update, answer yes if you wish to or no if you dont. then you can simply exit and play games online
If this info was useful please vote for me
Feb 27, 2011 | Nintendo Wii Console
My Wii will not connect to my router. I have tried all the routerlogin.net and .com solution attempts. Also the 192.168.1.1 stuff. No luck. Netgear tells me I have to use their support tech at $69.995....
Welcome to Fixya. If you want to connect you Wii to the internet wirelessly first we need to know the settings of your router. Listed below are the steps on how to access your router. You need a working computer connected to the router to access it follwed by the steps on how to connect our Wii.
How to access the Router:
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Now that we have the information needed lets connect your Wii to the internet.
1. Select Wii Settings
2. Then Internet Connection Settings
3. Search for an AP or SSID
4. Input Security Key or Network Key
5. Test the Connection.
Other Suggestion
Did this connection used to work but has suddenly stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii and test for proper response.
The Wii may have detected and set itself to the wrong security type during the initial connection set up. Try creating a new connection file and going through the connection process again but be sure that when the Wii asks for a security code, the type shown on screen (WEP or WPA) is what your router is set to. If it is different
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker
Don't forget to say thanks. Thanks for using Fixya
Feb 22, 2011 | NetGear WNR1000 Router
I do not know how to log on to my wireless router-netgear wnr2000 to make changes in order to operate my WII from it.I have gone to the support nintendo website and tried the steps to connect the WII to...
Welcome to Fixya. To access your router you need to use a computer that is connected to it. Open a Browser then type192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remeber the details. Make sure you connect to your SSID and enter the Network Key to make it secure. Then connect your Wii to the router using that information.
If you think this is helpful rate me and dont forget to say thanks. Thanks for using Fixya.
Feb 06, 2011 | NetGear WNR2000 Wireless Router
Trying to play nintendo on line. have a new wireless router/modem it is giving an error code of 52230 and says unable to connectg to server. any ideas?
Your nintendo consule without a technical malfunction should integrate to a network. The wii fii feature allows to network by wireless recognition of another consule on the network. The situation requires finding another consule owner to network with. Both consules would communicate by wii fii signals, only require recognising another consule owner that would allow device to device connectivity. keep in mind that, the error message is a computer message indicating a break in the link that could be created once another consule is recognised.
The error message would be intergrated into a network hub once each owner of the consule enable a feature on their device to accept communcation.
The wii fii feature only is advantage to the consule owner compared to connectivity that would have been performed by connection cables earlier in the invention of video gaming.
Advice
Find colleages with similar devices, inform them about wanting gaming network connectivity to allow possible network. keep in mind that, networking is a connection involvign entities where people are a requirement..
Your situation would be possible by human networking to make possible, device to device; that would only communicate when enabled features disabled.
Dec 01, 2010 | Nintendo Wii Console
How do I connect the Nyko wii remote to the wii?
You must first sync the remote and consul.To do this you take off the back of the remote then hit the red button.Their is a red button on the consul that you need to push at the same time then push the a button on the remote.If you are trying to hook up the old style Nintendo controller then you plug the controller in to the end of the wii remoute the same way you hook up the nunchuk.
Mar 08, 2010 | Nyko Net Connect For Nintendo Wii
Help
yes,that's very possible.you can connect directly the wii to your lan if your wlan is having some kind of a glitch that will not allow you to connect to the internet.now,once connected via lan,you can browse on opera per the message you've been getting and see if you can follow their instructions to solve the matter.later on if you still can't connect,you might want to set-up again you wii connect settings.make sure your router is working properly and is set to detect/accept your wii.also,your wep or wpa password should exactly be the one you need to key in on your wii internet setting.if it's wpa,try to select AES.no guarantees.hope this helps.
Apr 27, 2008 | Nintendo Wii Console
NetGear WGR614 Wireless Router Logo
112 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
