Question about Aspire Acer 7520-5071 Notebook
No internet connection on aspire 1 notebook
My wireless was working but then went of.the wireless icon is replaced by the battery icon.when i click on network centre nothing happens
  • lou2k7 Jan 22, 2009
    thanks but tried that.any more hints plz
  • 50 Answers
This sounds like a power save feature as laptops tend to disable networking features when the battery gets low.
Plug in the power cord and see what happens
Posted on Jan 22, 2009
  • megax01
    megax01 Jan 22, 2009
    Ok 2 questions what OS are you using and are you using the OS to control the wireless or another third party program?
Not connect to the wifi
Locate the Wireless LAN switch located on the front of your Acer Notebook. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Move the switch to the right to turn on Wireless connections. Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks. Select the network you want to connect to and click "Connect."
or
Power on the Acer Aspire laptop. Right-click the wireless Internet icon in the lower right corner of the desktop. Select "Enable" from the pull-down menu. Right-click the wireless icon again. Select to view all available wireless networks in the area. Momentarily a window appears with all of the available Wi-Fi networks. Select the Wi-Fi network you want to connect to, then type in the password (if required). Click "Connect," and your Acer Aspire computer connects to the Internet. Hope this helps.
Jan 16, 2013 | Acer Aspire 3690 Notebook
Turn on WIFI on Aspire 3620
or
hope this helps
Oct 11, 2012 | Acer Aspire 3620 5560 TravelMate 2400 2420...
Wireless lan not working on my acer aspire 4520
The wireless feature (Wireless LAN) on an Acer notebook allows you to connect to available networks. This convenience allows you to use the Internet with network cables, modems or network installation. Acer laptops come with a wireless switch to turn the wireless feature on or off. Once you enable the wireless feature, your Acer notebook can connect to wireless networks within range.
Instructions:
1.Locate the Wireless LAN switch located on the front of your Acer Notebook. Move the switch to the right to turn on Wireless connections.
2.Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks.
3.Select the network you want to connect to and click "Connect."
Sep 07, 2011 | Acer Aspire 4520-5582 Notebook
I have a notebook aspire 6930, i've had it just barely over a year, and a couple days ago my internet just wouldn't connect. When i push the touch button to turn the wireless LAN on it does not light up...
1) Make sure Wireless Lan is Enabled by pressing the light button of it
2) Click with right button on the Battery Icon (on the botton bar aside clock)
3) Select Windows Mobility Center (a window will open up)
4) Click on "Turn wireless on" button.
Jun 12, 2010 | Acer Aspire 6930-6455 Notebook PC
The wireless switch is turned off cannot be turned back on cannot get internet connection
Start by
You can also disable the power management from turning off this device
Go to Control Panel and then to Device MAnager. Click on the wireless device and then on Power Management tab and uncheck the first box.
May 27, 2010 | Acer Aspire 6930-6455 Notebook PC
Internet connection problems
I had this problem too with my kid's Aspire One (Linux). It happened after I borrowed it to use at a PTA meeting, and the battery ran out on me. Thanks for the solution. It's all working now. Here are some detailed non-command line instruction for the same fix, for those of us who need it:
This is to find and delete the networking folder:
1. From the regular Aspire One options page, go to the Files panel
2. Click on the triangle to see more icons
3. Click on MyFiles, which opens a file manager window.
4. In the menu bar, select View->Hidden files, to show a tick in the box. (Sorry, I'm translating from a German display, so the option names may not be spot on.)You should be in the "My Disk:///" directory.
5. Find folder "gconf" and click on that
6. Find folder "system" and click on that
7. You should now see folder "networking" listed as one of the folders.
8. DELETE IT! (Right click on the networking folder, and select option delete.)
Okay, once you have recovered from the fear of deleting goodness-knows-what-file because you are just following some internet instructions, you have to re setup your wireless connection:
1. Shut down all those windows, and go back to the regular Aspire One options page.
2. Click "Settings" on the bottom right.
3. Click icon for "Netwrok Center". If this works, and a window pops up then it's going well.
4. Click on "New", and follow the on screen instructions to connect and re-setup your WLAN or LAN.
Oh, and do check that the little network switch near the bottom right of the keyboard is switched on. It should show an orange light.
Hope this helps
Oct 18, 2009 | Acer Aspire One Netbook 8.9" Notebook
Please Help -- Acer Aspire 3000 Wireless Stopped Working When I R
If your wireless network adapter is OK then :-
If your wireless connection is on the Task Bar the right click on this Icon and left click on REPAIR.
If no Icon on Task Bar the click on Control Panel - Network Connections - then right click on your LAN Connection and left click on REPAIR.
This will get your wireless router to issue your wireless card with a new IP address.
Apr 22, 2009 | Acer Aspire 3000 Notebook
My daughters acer one will not connect t the internet and there is no connection icon in the system tray can anyone help
Right Click on "My Computer"
Select "Properties"
Select " Hardware" tab
Click "Device Manager"
click the "+" sign network icon
check if the wireless card is there.
if you see the wireless icon..
then Go to Control Panel
select Network and Internet connection
Select Network Connection
then Right Click the wireless connection ( menu will pop out)
check if the wireless is Enable
to restore the icon to the desktop: select properties after the instruction above
on the general tab
check the " Show icon notification area...
Check "notify me when......
Mar 15, 2009 | Acer Aspire One PC Notebook
Aspire one, linux lite, wireless connection issue
Reset the network adapter
Go to Control Panel\Network and Internet\Network Connections
Right click on Wireless Network connection. Click disable
Right click on it again and click on enable. It should work .
Dec 15, 2008 | Acer (BCM94318MPG) Wireless Adapter
Aspire Acer 7520-5071 Notebook Logo
Top Aspire Computers & Internet Experts
Jax Planet
Jax Planet
Joe Goldman
Joe Goldman
john smith
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
