Question about Endurance T3 Treadmill
I have a Trotter 350 treadmill. Is there a re-set button on it ?
2 Suggested Answers
  • 3 Answers
SOURCE: I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Posted on Oct 20, 2010
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
Key pad enter + numbers not working trotter 685
adjust the reed switch, test for open or faulty, clean it, and tight the connector fery weel , see the diagram attached
2) replace the batteries old by new ones, and clean the contacts batteries.
3) tight the ribbon cables for keypads, clean it too.
God bless you
Feb 22, 2013 | Treadmill Doctor Cybex Trotter685 900t By...
Change a treadmill belt
Check the video which will help you do the same. All most all treadmill follows the same procedure.
Dec 15, 2012 | Treadmill Doctor Cybex Trotter400t 410t...
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
B. Clark
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
Endurance T3 Treadmill Logo
32 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
vinayghl
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
