Question about Kenmore 17439 Built-in Dishwasher
Kenmoredishwashermodel#665.13443k901 heated dry light blinks rapidly and cant clear it
2 Suggested Answers
  • 338 Answers
SOURCE: Kenmore 24 in. 17842 dishwasher heated dry light blinking
you have a shorted keypad. you will need to replace it. you can get parts at jacobyparts.com
Posted on Dec 01, 2008
Kenmore Elite Mod. 66513922K010: Complete light keeps blinking. It had a leak, but is fixed. Now how do I clear the blinking light?
Press (one after the other):High Temp, Heated Dry, High Temp, Heated dry. You can also try throwing the breaker (at the house breaker box) for 5 minutes to see if that clears the problem.
Jul 20, 2016 | Kenmore Washing Machines
Clean light just blinks and will not run
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks wich means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller; or the problem could be that 1 of the 2 switches inside the door latch is not getting engaged fully. Most of the time, I find that the cause to this problem deals with the latch, or the switches in the latch. If something (like a soda) gets spilled into the latch, it can cause the plastic parts to stick and not slide to engage the 2 door switches. You might need to take the latch out (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove it (without pulling out the dishwasher), by using a small screwdriver to release the little catches on either side of the "tongue" or "tang". Bend the center part down slightly more to give it more force, and then re-insert it. Then run the diagnostic cycle (by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry), let it run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Dec 17, 2014 | KitchenAid Kitchen Aid Superba Series...
I have a kenmore ultra 665 1627. The green front panel light blinks. And we can not run a cycle. Thanks
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller; but the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Jul 27, 2014 | Kenmore Dishwashers
Why is the Rinse Cycle and Drying not working
Unfortunately you did not specify the model dishwasher so I'll give you a general answer.
(The indicator light, straight from Washing moves to completion stage where the light blinks rapidly) I believe you means the "End LED" (LED 3) blinks rapidly. If this is true and according to your description of failure (no drying, no rinsing) I think that appeared alarm AL04. It means the thermistor (NTC) not compliant - probable failure of the component that detects the temperature .
I suggest you to check: thermistor NTC, wiring and electronic.
24464652-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Rapidly flashing any combination of four LED diode means failure.
Dado
May 20, 2014 | Ariston Technologies Dishwashers
I have a 665.16039401 kenmore dishwasher and the clean light continues to blink. I can not run any cycles
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... You say it blinks 7 times, pauses, and repeats, right? Well, 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches. Usually, the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. If the problem re-occurs, then the cause may be a bad heating element or a bad controller.
Mar 24, 2012 | Kenmore 15129 Built-in Dishwasher
Kenmore dishwasher clean light is blinking and now wont wash dishes what can i do?
try this and make sure you water is hot enough to cycle your washer, as it has a temp. sensor for this.
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
Oct 20, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Blinking clean light, will drain with cancel button,wont wash
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Lights blinking and won't clear
the solution #3 should work.. you may want to try again.... first turn off the Breaker to cut power then wait a few minutes then turn back on, then within 6 seconds try (Heated dry)(normal)(heated dry)(normal).. all lights should light up then you know that you are in the service cycle, and the unit should go into a self test and clear the fault. The test take about 30 minutes. let me know if you can get into it...
Aug 25, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 17439 Built-in Dishwasher Logo
117 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
