Question about Car Audio & Video
I bought some rear speakers for my car 6 x 9 and there is no wires at the back what do i do. how do i connect them to my unit
  • 63 Answers
Easyest way is to either disconnect your rear standard speakers (if you have them) and attatch the wires to the original wireing
Or you could daisy chain them (attach to standard speakers) [front or rear]
let me know...
Matt
Posted on Jan 22, 2009
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
How to hook up a kenwood car sterio in a 1992 saturn sl2 car.my radio was stolen and a bought a kenwood and we dont have the color codes for wiring them together
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 06, 2010 | Car Audio & Video
Need to know the wires to install a deck for 97
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
Sep 02, 2009 | 1995 Toyota Celica
Connecting the speakers to the Alpine CDA-7940
Typically the orange wire in a car stereo are connected to the + always on ( it's usually for back up memoru). ordinary AWG # 18 flat cord will be sufficient for the purpose
Jun 26, 2009 | Alpine CDA-7940
I Need the Wiring guide
May 21, 2009 | 1992 Saturn SL2
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
Wiring a stereo
Here is the radio wiring color's and what they do, all have the harness installed.
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: Blue
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Nov 12, 2008 | 1998 Mazda Pickup
Wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
Sep 09, 2008 | JBL LC-S960 Car Speaker
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
