Question about GE PTWN8050MWW Washer
The infusor on my GE PTWN8050MWW Washer is detached. It is spinning loosely and floats up when the tub is filled. How do I fix it?
If the screw holding the infusor to the shank is not broken, more than likely the shaft broke. That is what happened to mine. The part is like 339 bucks and you need to tear it apart to install it. Sorry.
Posted on Feb 10, 2013
  • Dan Boone Feb 10, 2013
    Here is a conversation that will shed more light on it also: http://www.managemylife.com/mmh/question...
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Loose tub on GE WJSR2080V
Reach (or look) over the tub, just under the metal top, at the four corners of the machine to see if the rubber tab dampening straps are OK. (not broken) If broken, use putty knife to push in 2 spring clips at very top of front panel (a couple inches in from the L and R side) and pull to take front panel off. Remove two 1/4 hex head screws holding top to side panels. Remove top. (looks like your model has a lid switch which can be unplugged by the back splash.)
Also check that the inner tub does not rock independently of the outer tub. If it does, pull agitator and tighten large left hand threaded nut.
Posted on Sep 13, 2008
  • 151 Answers
SOURCE: I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Posted on Dec 24, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
Ge wjrr4170 no spin
Remove the front panel, then look at the motor to see what codes the motor is flashing. There should be a green light on the motor that will be flashing. Post back your findings.
Nov 13, 2012 | GE WJRR4170E Top Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Purchased a GE washer WHRE5550kww need to know why it isn't filling to the top 'holes' when set on large/super wash?
Hello....I don't know the answer to your question, but would like to know if you like this machine in general, are you happy you bought it??? Would you buy it again? Thanks
Aug 04, 2009 | General Electric WHRE5550H Top Load Washer
Washing machine will not fill with water just aggitates
Check the float bulb in the bottom of the tub and the switch below the tub. It may be stuck in the up position telling the computor that the water has filled. The timer is not supposed to advance to another process engagement until the water floats the bulb and changes the bottom switch position.
Jun 21, 2009 | GE WBSR3140DW Top Load Washer
WASHING MACHINE LEAKING FROM BOTTOM
Check the two lengths of 1/4" plastic tubing, the long one that runs from the filler at the botton left side of the tub, and the short one that runs from the load switch (water level switch) to the shield assembly (formed plastic cover for the controls). When under pressure, the tubing can come loose from the plastic nipple on either side of the shield, leaking water while the tub is filling. If either length of tubing is detached from the nipple, reattach the tubing and use a 1/4" hose clamp to prevent it from detaching again.
Mar 14, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer won't spin and keeps filling
one thing is wrong is balance.That's why it knock the wall down.Don't know to much about GE.But I would check the dasher to see if it's down.But the belt could be broken under the washer.
Mar 13, 2009 | GE WSKS2060WWH Top Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
GE PTWN8050MWW Washer Logo
337 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
