Question about Danby DMW773 Microwave Oven
Does anyone know where the fuse is located on a danby DMW749SS microwave oven
I think it is a blown fuse as the clock is on light is on when i put in the time and press start nothing happens.
  • Danby Master
  • 17,129 Answers
WhIzAtIt
  • 136 Answers
SOURCE: Danby DMW753W 800 Watts Microwave Oven Problem
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Posted on Sep 15, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Change clock from 2400 hr to standard hr time
Contact Danby Customer Service US / Canada
You should be able to download or order your owner's manual otr maybe they can walk you through the procedure.
Posted on Jan 03, 2009
  • 75 Answers
SOURCE: Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Posted on Jan 23, 2009
carputers
  • 255 Answers
SOURCE: my microwave keeps beeping several times and i put
it junk replace it befor it burns u house down
Posted on Sep 07, 2009
SOURCE: i have danby dmw112 1100 watts microwave that will not cook
i have power and light is on can not press any numbers or start button or any other button.it keeps on peeping steady
Posted on Jun 25, 2010
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Mar 21, 2011 | Emerson MW8107WA Microwave Oven
No power in the microwave but there is electricity at the wallplug
No power and or NO lights at all,indicate a blown fuse.
Locate and replace the fuse inside the unit.
Feb 25, 2011 | Maytag Appliances Over-the-Range Microwave...
My Danby Diplomat 1000 Watt microwave suddely stopped workinmg (display went dark, no door light, nothing). I'm thinking it could be a fuse?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 26, 2010 | Danby DMW1406 1000 Watts Microwave Oven
Everything on our microwave still works( Clock,lights, fan) except it will no longer heat anything you put in it
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
NO POWER
You can try to check the AC fuse, which you can see after opening the top cover, Check if there is any loose contact, corrotion or blown off. If the fuse is blown off you can replace it by a new one with a rating 10amps.
May 29, 2009 | Goldstar MV-1501 Microwave Oven
hope this helps.
Jan 23, 2009 | Danby DMW1153 Microwave Oven
Need owners manual
You can contact Danby Customer Service US / Canada.
Oct 21, 2008 | Danby DMW139 Microwave Oven
Not working
Sep 18, 2008 | Danby DMW1153 Microwave Oven
How to set the time
Try this combination: Cancel, Clock, ### (time numbers), Clock again If that doesn't do it, contact Danby here: http://www.danby.com/page.asp?code=7
Sep 04, 2007 | Danby DMW1400 Microwave Oven
Danby DMW773 Microwave Oven Logo
143 people viewed this question
Top Danby Microwave Ovens Experts
zappal
Andrew Taylor
Andrew Taylor
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
