When I turn on the Kenwood KR-9600 Receiver it plays for 10 minutes the shuts off
When I turn it on it clicks when the relays turn on and it plays after ten minutes or so it shuts off when I turn it off it used to click it does not now.
techman
  • 3130 Answers
SOURCE: Double clicking sound- no power
The relay contacts are most likely bad in the relay and will most likely happen again. If you know how to solder, take out the relay and look up the numbers on the internet and see what you can find. If not, try to find where the manufactuer is located and call them to see where you can get a new relay. Good Luck
Posted on Mar 28, 2007
  • 17 Answers
SOURCE: Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Posted on Jan 01, 2008
  • 4234 Answers
SOURCE: Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Nov 28, 2008
SOURCE: kenwood am/fm stereo receiver kr-596
theres a fuse that blew.. ive had to replace mine three or four times. just open it up and the fuse will be somewhere close to the volume knob
Posted on Aug 07, 2009
satavlad
  • 405 Answers
SOURCE: yamaha receiver will not turn on. just a clicking
Your unit have had detected a fault and enter the protect mode. To determined, what exactly wrong with it, you will have to take it to Yamaha authorized repair facility.
Posted on Dec 26, 2009
How can i repair amp
Looks like the amplifier output transistors have blown (hence the pop). Quite expensive too repair - I would have a look on eBay for a cheap used but working Kenwood receiver, it would probably work out cheaper.
May 10, 2014 | Kenwood Audio-video Stereo Receiver Kr...
Kenwood kr v5560
You can use either Tape 1 or Tape 2 (play) if not in use.
Aug 06, 2013 | Audio Players & Recorders
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
Do not hear the second click on speaker relay on kenwood KR-V5570 why?
I will assume no audio is coming out of your speakers.
When the reeciver starts up It looks at the load (resistance) of the speakers attached to see if it is reasonable. If It appears there are no shorts in the speakers then the speaker relay will close (second click) and send signal to your speakers. If there is no second click then either the the reciver is detecting a problem with speakers or cables or the detecting circuit has failed. I would start by disconecting all speakers then start the receiver up. If your not getting a second click after about 4 or 5 seconds then the receiver will need service. If it does click then shut receiver off, and hook up one speaker at a time, then re-start receiver. If one speaker suddenly makes the system fail then you have found your problem. If you have a Volt/Ohm meter, set it to resistance(Ohms) and measure each speaker. Anything Under 4 ohms will be a problem.
Good Luck
Apr 01, 2010 | Kenwood Audio Players & Recorders
How do I hook up the Onkyo DS-A2X to my Kenwood KR-V5560?
Hook it up just like any basic DVD player. Run the 3-headed RCA connector as follows to your receiver:
Red/White Audio Out to Audio Left and Right of (you choose one unused):
Tape 1 Play
Tape 2 Play
Video 1 Play
Video 2 Play < preferred
Yellow Video Out to: (you choose one unused)
Video 1
Video 2 < preferred
or
Video In on your TV
May 26, 2009 | Kenwood KR-V5580
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Nov 19, 2007 | Kenwood KR-X1000
KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Oct 25, 2007 | Kenwood KR-X1000
Standby mode, shuts off
After 10 years of use probably best to replace with a new unit. Most will be hard to find exactly wich little bit is broke.
May 23, 2017 | Kenwood KR-A5080 Receiver
57 people viewed this question
 Grubhead
Grubhead
