Question about HP DeskJet 3550 InkJet Printer
Printer does not function
Printer is on (light is on) but it does not respond to any print command.
(the command does not execute)
  • nu3nu Jan 28, 2009
    aaaa
  • 24 Answers
Friend,
In most cases this is caused by a faulty driver or a broken printer cable. Please try to print an internal test page to ensure the printer itself is working properly, then replace the cable and ensure the driver is pointing to the right port if the internal test page prints properly. Also you could try to print the driver's test page (driver properties > Print test page > answer "Yes" anyway, since answering "No" only produces a bunch of suggestions that won't help you solve the problem!). If this works, the problem resides somewhere between the driver and the application(s) you're trying to print from.
//Al
Posted on Mar 08, 2009
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Won't respond to computer, light on printer alternates flashing between green and yellow
  1. Start with the printer OFF
  2. Hold down RESUME button and then hold down POWERbutton
  3. release RESUME button
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Press 2 times for EEPROM reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Jo
Feb 19, 2011 | Canon i850 InkJet Photo Printer
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
Light flashing green and yellow will not print
Hi this is only a try it may work
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Jan 14, 2010 | Canon i850 InkJet Photo Printer
How to I access canon s600 ink pad
2. Release RESUME
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on s600)
Nov 13, 2009 | Cannon Canon i960 Photo Printer
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
I9900 printer has error 5B00 & won't print
You may need to change the ink absorbers. But try resetting the printer:
Canon I series service mode
1. Start with printer OFF
2. Hold down RESUME and then press and hold down POWER Button.
3. Release the RESUME but continue to hold down the power button
4. Press the RESUME twice, then release POWER button.
Now you have put the printer in Service Mode so it will accept Service commands. Here is the list of Service commands;
A. Press the Resume button once = Print Service test print
B. Press the Resume button twice = Print EEprom data sheet
C. Press the Resume button Three = Initialize the EEprom
D. Press the Resume button Four = Clear Waste INk Counter
E. Press the Resume button Five = Change Destination settings
F. Press the Resume button Six = Head Refreshing (Cleaning)
G. Press the Resume buttom Seven, Eight, Nine, = Not used
H. Press the Resume button Ten = Return to selection Menu
To EXECUTE anyone of the above commands you "MUST Press the Power button one time. Then the function will be executed. After that function has been executed the printer will REMAIN in Service Mode,.. waiting for another command. You can only execute one command at a time. If you are through with all the commands you want to do, just press the power buttom one more time and it will turn the printer off and you will be out of Service Mode. One more note. When you get the printer into Service MOde and it is ready to accept a command, the green light will be on and steady. As you issue a command by pressing the resume button, it will alternate the color from green to orange with each press of the resume button. Remember, if you issue either one of the commands to force a print make sure you have paper installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP PSC 950 print problem
It is cheaper to buy a new one than dewll to fix an old printer.
So called experts can tell me only by asking stupid questions
like; "did you turn the power on?" did you put a paper in it? did
you check the ink cart and so on". Duh!
For the sake of HP making more money, I have sent this printer to its
eternal resting place. Problem solved!
--Sam
Jul 12, 2008 | HP PSC 950 All-In-One InkJet Printer
Will not respond to print command
download the newest software from web and install it. if its not helping, check connections, if your printer has a display and menu key, you can print aut configuration and demo sheets, to see that the printer itself works. if not the last option is firmware upgrade.
Jan 31, 2008 | Konica Minolta magicolor 2400 Laser...
HP DeskJet 3550 InkJet Printer Logo
116 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
