Question about Vizio Televison & Video
Cant change channels with dish network remote
New vizio tv and the channels wont change with the dish network remote until tv has been on an "warms up"
SOURCE: remote problem
I understand Ilo's are made by Tatung. You may try 0055 or 0003. I haven't confirmed this, but it's worth a try. http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
Posted on Aug 24, 2007
  • 362 Answers
SOURCE: I lost the remote for
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
lone99star
Posted on Jan 09, 2009
  • 718 Answers
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Posted on Mar 16, 2009
  • 10 Answers
SOURCE: Vizio won't turn off
This could be a mainboard problem. Sometimes one of the fuses may be bad and may freeze up causing the TV to not be able to power off.
Posted on May 23, 2009
satavlad
  • 405 Answers
SOURCE: SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Posted on Nov 03, 2009
Cant change channels on my new Vizio HDTV with the dish network remote
There is no setup codes for Vizio TV with Dish Remote control.
Jul 25, 2012 | DISH Network IR Remote Control
Dish network remote turns tv on but wont change channels
1) clean the contacts batteries.
2) change by new batteries
3) resolder wires connectors batteries
4) Open the remote control, and clean the keypads very well with special spray contact R. Shack
5) Otherwise you must go to the repair shop TV, FOR Fix it
GOd bless you
Jun 18, 2012 | DISH Network Televison & Video
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
Need code for my vizio tv so I can program my dish remote
We would be happy to help you with getting your DISH Networkremote to control your TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Vizio TV; here some of the codes we currently have: 505, 598, 627, and 593. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Dec 01, 2010 | Vizio E322VL 32 in. LCD TV
The dish network 2nd remote isn't working I put in a new code because we bought a new tv for that room. Now, i can use the dish remote to do everything without the tv remote but NOTHING works on dish...
Hello, you may have gotten this resolved already, but if not, here are some simple steps to get this resolved. Follow these simple steps on our website, and you will be good to go!!! For this also, you will want to be at TV1, in the system info screen. Menu twice with TV1 remote. :)
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
Nov 28, 2010 | DISH Network IR Remote Control
Cant make the remote connect to the TV. Got it set up to the TV. Wont change channels and no guide will come up.
Hi there, Tommy Faust with DISH Network Executive Offices here. It sounds like the remote is not programmed to the receiver. I have included steps below to get that programmed.
1. Go to the System Information screen and check the number under Remote Address.
2. Hold SAT until all buttons on top of the remote light up.
3. Let go and while SAT is blinking enter a number between 1-15 on the number pad and press #
4. Press record 3 times and see if the number changed.
Sep 21, 2010 | DISH Network IR Remote Control
Tv cannot be controlled by remote control, the one that came with the tv or the dish network remote
We would be happy to help you with getting your DISH Networkremote to control your TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Vizio TV; here are some of the codes we currently have for it: 505, 598, 627, 888, and 802. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for your Vizio TV until you findone that is compatible with it.
Phillip Chang
Jul 11, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I programmed my dish network remote to turn my tv on and off,and after I programmed it I cant change the channels on the satellite it just controls the tv. The remote has a 21.0 on the back of it and my tv...
You need to try a different code,505,506,516,523,526,566,573,612,627,647,652,653,654,655,656,658,659,664,665,667,669,670,679,680,704,717,730,738.....hope this was helpful....
Apr 25, 2010 | DISH Network IR Remote Control
Need the codes to program my dish network remote ???
We're happy to help you with getting your DISH Network remote addressed to your TV. We're going to start by pressing and holding the TV button on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Vizio TV; here are some of the codes we currently have: 505, 598, 627, 520, and 627. Press the pound (#) button to save the code in your remote. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Vizio TV until you find one that is compatible with it.
Phillip Chang
Feb 05, 2010 | Vizio L32 32 in. LCD HDTV
Can't get the tv/input button to work on dish remote control with vizio tv. need it to view local channels run off antenna
Hi there! This is Kimberly Escobar with Dish Network. Just ran across your post and wanted to help. In order to get the remote to possibly work the Inputs on your T.V the remote needs to be programmed to your Vizio T.V. In order to do this we have certain codes that can be integrated into the remote. Some of the codes for a Vizio T.V are 505, 671, and 627. The procedure is press and hold the clear T.V buttton located at the top of your remote until you see all the other buttons light up in red, once they are lid up enter one of your codes followed by the pound key for example: 505#. The T.V button should light up 3 times you can then try the remote to see if it works your T.V
Unfortunately we cannot promise it will completely function the T.V so it might bu that input button does not work. If you need any help please contact us directly at 1800-333-DISH.
Oct 19, 2009 | DISH Network IR Remote Control
Televison & Video Logo
93 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
