Question about Logitech Harmony 890 LCD Remote Control
My harmony 890 remote has worked perfectly for a long time, but all of a sudden it now only turns on/off the tv but will not turn on/off the fios cable box and av receiver - help please! PS - I don&#
3 Suggested Answers
  • 89 Answers
SOURCE: remote stopped working
Hey!
I have found when you are not able to control devices, a firmware update will sometimes fix the issue. If you do not know how to do a firmware update, please look at the following link:
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=10747
If the firmware update does not work, you may have to learn the power commands from the original remotes. The following link shows how this is done:
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=9603
I hope this helps!!!
-Kennedy
Posted on Mar 05, 2010
  • 19 Answers
SOURCE: Harmony 890 Remote
in the harmony remote software (7.4.3) go to the device (Bell receiver) under the devices tab and select settings. select the second radio button (adjust power settings) and click next. select "i want to turn this device off when its not in use" and then click next. Continue answering the questions, and then update your harmony remote.
Posted on Jul 08, 2008
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
The Harmony 890 turns the TV on and off, but it does not do the other functions.
Hi. You can learn the buttons from the original remote so that they work
In the software, click 'Learn IR' next to the icon for your TV. Follow the on-screen instructions to learn the buttons.
Hope that helps.
Mar 20, 2010 | Logitech Harmony 890 LCD Remote Control
My 890 is no longer working correctly. It won't
I had a similar issue and only needed to "re-configue" the remote... Basically, just try plugging it back into a USB cord ( connected to your computer) and go to the original programming home page and click the "Update button." It will re-program your remote as if it was new.. Over time your Harmony may lose or forget the frequency of your various components. This happened to me. Also, make sure the remote has a full charge while you're programming it. Give it a try !
Feb 07, 2010 | Logitech Harmony 890 LCD Remote Control
My Harmony 890 turns everything on and off, but when I am in PVR it just suddenly stopped letting me use any of the buttons (ie, menu, guide, channel, volumn). what do I do
I would hook the harmony back up to your computer and the update the remote. If that does not fix the problem then I would down load the firmware and then update your remote. If you still have problems I would check your check your buttons in the program. You can do this by logging onto your Harmony account, select the Activities tab and press on the “customize buttons” under the activity you are trying to fix. Scroll down to the menu exit info buttons and see if there assigned to the correct device and correct command. If none of this works I would see if the menu button works in another activity like Watch TV or Watch DVD.. If the menu button does not work in another activity then the remote may be broke. If it does work then I would try the original remote with your DVR and see if that works. If that works then I would manually teach the harmony remote. Harmony calls this “Learn command” It’s a button in the lower right corner while in the “customize button” tab.. If none of this works then pull out your 45 and put a hole in it.
Hope this helps
Nov 28, 2009 | Logitech Harmony 890 LCD Remote Control
Turns on fios box and receiver but not television
I would hook the harmony back up to your computer and the update the remote. If that does not fix the problem then I would down load the firmware and then update your remote. If you still have problem I would manually teach the power command (Learn) to the harmony remote. Harmony calls this “Learn command” It’s a button in the lower right corner while in the “customize button” tab.
Hope this helps
Nov 09, 2009 | Logitech Harmony 520 LCD Remote Control
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 890 will no longer operate the tv, dvr,or sound
Mar 18, 2009 | Logitech Harmony 890 Universal Remote
Harmony 890 Remote
Apr 22, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
71 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
