Question about GTech G-RAID 500 (90700501) 500 GB Hard Drive
My g tech wont show up in disk management - GTech G-RAID 500 (90700501) 500 GB Hard Drive
Dvd recorder hard drive not recognized when used as an external
Open Start menu
Click the right mouse button on Computer
On the pop out menu click on Manage
In the left hand menu click on Disk Manage
Your drive should show here if it is plugged in.
Delete all partitions
Now create a partition, format it how you want.
Mar 21, 2014 | Hitachi Computers & Internet
I just bought a Dell Back-up plus 1 TB hard disk . when i plug in the USB cable it does not show up on My computer but it shows on "Device manager" and "computer management" .. so i cannot use it as a...
The only thing that I can think of is that you need to go into computer management and click on the "disk management" sub-heading under storage. From there all of the hard drives in the computer should show up. Find the new hard drive in the list and right click on the part where is say Disk 1 or Disk 2 or which ever disk is the correct one (it should be around 930gb or so). Then select initialize disk, and follow the wizard through the choices to setup the disk as a basic hard drive. After the disk is initialized you need to format it and then you should be access the drive in my computer.
Austin
www.we-supply.com
Aug 08, 2013 | Computers & Internet
My new a 4 tech camera wont split
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
May 28, 2011 | A4tech PK-635 Webcam
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
Mar 23, 2011 | Western Digital Scorpio Blue 250GB PATA...
Hi pm, I have problems encounterd with my external drive which is wd5000BEVT..when i connect it to a port, the computer says that "found a new hardware" but when i search for the drive...
Goto start then in the search box type in computer management then click on computer management then go down to disk management it will show the drive as unformatted you will have to format it to get it to show the drive.
Right click on that drive that is unformatted and format the disk.
Nov 26, 2010 | Western Digital WD HDD 500GB SATA 25"...
My LaCie Rugged Hard Disk wont show up on my computer!!! need help asap or im getting firered!!
External hard disks can fail for a number of reasons, but check the device manager and disk management first to see if it is recognized (assuming you are using Windows).
Here are some more ideas: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Sep 07, 2010 | LaCie Rugged All-Terrain (301017) Hard...
DVD wont recognise disc
If your DVD drive don't show up in device manager and if there's no yellow exclamation mark in device manager, try to check IDE or SATA cable connection from your DVD drive to the motherboard. Also check the cable itself (are the wires inside broken?)
Feb 01, 2010 | LG GSA 4163B DVD±RW Dual Layer Burner
Harddrive does not start up...computer recognises
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
Nov 17, 2009 | Western Digital Passport WDXML800UE...
External hard drive
I found that explorer doesn't show a drive that isn't partitioned. I went to the Disk Manager and it shows up there. I right clicked for new partition and assigned it a drive letter. My problem was fixed. Windows XP
Disk Manager. under:
Control Panel, Admin. Tools, Computer Mgr, Disk Manager.
Aug 26, 2008 | Computers & Internet
Simple tech mini 320 gb external hard drive
It mostly comes with 3 years of warranty but you cant utilise warranty just for being "not recognized".
Try to trouble shoot the problem by using the technical suppport offered for the item
Apr 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
GTech G-RAID 500 (90700501) 500 GB Hard Drive Logo
Top GTech Computers & Internet Experts
Lawrence Oravetz
richie46
Bill Boyd
Are you a GTech Computer and Internet Expert? Answer questions, earn points and help others
