Question about Technics Audio Players & Recorders
Wheel does not adjust fr correct speed to play 33's or 45's
  • 25 Answers
With what type of turntable are you refering to as this would be a vital piece of detail necessary to diagnose accurately.
Posted on Mar 15, 2014
DTC code C1226
Definition of Diagnostic Trouble Code C1226 Buick: Right Front Excessive Wheel Speed Variation Cadillac: Right Front Excessive Wheel Speed Variation Chevrolet: Right Front Excessive Wheel Speed Variation Chrysler: Brake Pedal Travel Sensor Circuit Dodge: Brake Pedal Travel Sensor Circuit Ford: Brake warning indicator output short circuit to ground. GMC: Right Front Excessive Wheel Speed Variation Jeep: Brake Pedal Travel Sensor Circuit Lincoln: Brake warning indicator output short circuit to ground. Mazda: Brake warning indicator output short circuit to ground. Mercury: Brake warning indicator output short circuit to ground. Mitsubishi: FR inlet valve Oldsmobile: Right Front Excessive Wheel Speed Variation Pontiac: Right Front Excessive Wheel Speed Variation Saturn: Right Front Excessive Wheel Speed Variation Toyota: Open or short in hydraulic brake booster solenoid circuit (SA2/SPC/SPFR/SPFL/SMV1/SMV2/SBAL)
Locksmith East Aurora Ny 24 Hour Locksmith 716 249 2944 in East Aurora Ny
Jul 31, 2016 | Cars & Trucks
Will driveaxels cause a wobble in the front end?
it is possible that a bent shaft or failed cv joints will cause the problem
it depends if the wobble starts at a certain speed and gets worse up to a speed then stops or just gets to the point where steering control is lost
because the bearings have been replace along with tie rod ends I am tempted to consider that the axles are not the problem ( unless the repairs stated were done to fix the wobble ) but the the wheel bearing adjustment is not correct and that the fittment of the tie rod ends has altered the wheel alignment
consider a wheel alignment to correct a castor fault ( wheel wobble) and recheck the correct adjustment of the wheel bearings
if the cv joints are worn , dry ,they can be binding up and not altering angular movement easily which may appear as a wheel wobble
Oct 10, 2015 | Cars & Trucks
Holden commodore vx 2002 wheel movement from side to side on drivers side when lifted in the air. wahts the most likely cause?
Providing you have confirmed all wheel nuts are secure, whenever you have play in one of the wheels, it is most commonly one (or both) of the following:
1) mal-adjusted wheel bearing. Wheel bearings can be adjusted to reduce play. The wheel will need to be removed to access the bearing assembly. Bearings are usually only turned a 1/4 turn at a time, until play has gone.
2) worn ball-joint. Ball joints can be tightened to correct torque, but if play is still evident, the ball-joint should be replaced.
Hope this helps....
Nov 01, 2011 | Cars & Trucks
Feels like the stering has play in it and will this cause it to make the stering whell shake a little at higer speeds
Hello, It sounds like you need your wheels balanced and the play adjusted on your steering. At high speeds the wheels will wobble if they ate not balanced correctly. Jax or someone similar should be able to help you with that. Takes about an hour.
Mar 23, 2011 | Ford Expedition Cars & Trucks
I have a problem with the steering wheel shaking violently "sometimes" when I brake. I've had numberous trips to my dealer and they say they cannot replicate the problem. It is unsafe to drive, and I...
it happen in slow speed or high speed, do brake padel vibrate at same time when you feel steering shaking. if you tell me clear then only i can answer you, if steering shakes in slove speed it is problem with tyre ( fr both tyre need to replace) and if it happen with high speed it could be problem with wheel balancing, get wheel balancing done for fr both tyre, if problem not solved , please let me kmnow. thanks.
Aug 17, 2010 | 2007 Chevrolet HHR Special Edition
Wanted steps to unlock region code for Samsung DVD-C370
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player).
  • FF = fast forward, FR = fast rewind.
  • Region 2 players: FF, FR, FF, UP, DOWN
  • Region 3 players: FF, PLAY, FR, UP, LEFT
  • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
  • Region 5 players: FF, UP, DOWN, STOP, RIGHT
  • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen.
  • The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Jun 03, 2010 | Samsung Televison & Video
Brake light and abs lights are intermittenly flashing
check wheel speed senders clean and correctly adjusted. a wheel speed sender wire could have an internal break. an electronics diagnostic reader will pinpoint the problem as there will be a fault stored in the memory.
May 12, 2010 | 1999 Volkswagen Passat
My deck plays too fast and i must adjust pitch control to -2.5 to get the speed correct... is there a way to adjust speed internally?
this is calibrated from factory, the control board is faling check for any pot. If available, adjust a little the speed pot
Jan 08, 2010 | Stanton STR8-50 Turntable
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
