Question about Fuji FinePix A340 Digital Camera
How do you turn the flash off?
How do you simply turn off the flash on this camera?
  • 32 Answers
Christinaaa: You must pressed several times the FLASH button until the regular FLASH ICON (The Thunder Symbol) appears inside a circle. This mode is called "SUPRESSED FLASH"... SithPitt
Posted on Jul 05, 2007
Battery is charged. Camera will not turn on
Simple diagnosis, battery is not powering the camera. There are many possible reasons. If you value you camera, don't attempt anything - simply bring it to a compatible licensed service agent for a check up.
Apr 30, 2015 | Canon PowerShot SX40 HS Digital Camera 2GB...
Dismount
At the base of the unit is a compression ring used to secure it to the flash "shoe" of the camera. Turn the ring to right viewing the rear of the camera body. Then simply pull the flash straight back.
Aug 11, 2014 | Metz Cameras
Turning flash off on Nikon D60
Based on what you said, it appears that you want to know how to turn the flash off on your D-60.
On my D-90, you do this by rotating the mode switch on the top center left side of the camera one click counterclockwise, from the green automatic setting, to the white automatic with no flash setting.
You can also change flash settings from the menu. For my D-90, the manual says you use custom setting "e2." Check your manual for the D-60.
I never turn my flash off from the menu because it takes too long to turn it back on when you need it. Another alternative is to simply hold the on-camera flash in the down position while you shoot.
Apr 19, 2014 | Nikon D60 Digital Camera
Service manual repair
If you are having issues with the flash not firing due to the 'thermal indicator' coming on, simply turn the thermal indicator off in the settings panel and all should be sweet.
Oct 02, 2013 | Nikon SB700 Flash
Turn off flash
With the camera ready to shoot in Auto mode - you will see a little lightening symbol in the top right hand corner of the screen. This indicates the flash is turned on.
On the left side of the circular dial at the back of the camera you will see a similar little lightening symbol indented into the dial. Simply press on this side of the dial to turn the flash on or off as you desire.
The symbol on the screen will go off when you push this to indicate flash is off and return if you press again to turn it on.
Thanks for using FixYa.
Dec 30, 2009 | General Electric A950 Digital Camera
When i turn on my digital camera, in the upper left hand corner, there is a red, flash symbol which i don't know how to turn off??? Thank you in advance for your assistance.
You should be able to turn off your flash, or change the flash to a different flash setting by using one of the buttons on somewhere on your camera. The proper button is identified by the flash symbol, that looks the same as the one on your LCD screen, a jagged, down ward facing arrow, that looks something like a bolt of lightning. Simply press this, it will ether change the setting on your LCD, or bring up the settings that you can change manually by selecting whatever setting you want for the flash.If you don't want to change any of the settings, but want to clear the symbol off of your LCD screen simply hit the Display button that will hide those icons from your view and can be seen again simply by hitting display once more. I hope this is of some help to you, if not, consult your user guide or manual that came with the camera, it should explain exactly what to do. I hope that you have success, God bless...
Aug 16, 2009 | Cameras
Pop-up flash
Go to the menu RESET ALL may work. Then go back to the menu and set the settings to the way you want them, test the camera and see if the flash works.
Make sure that the flash settings are on and not turned off in the menu settings.
If the flash is on in the settings and it still does not work, then this camera needs repairs.
Jun 21, 2008 | Nikon Coolpix 5700 Digital Camera
I need to turn the flash off on my D-395 digital camera and I have no idea how.
Greetings punknarumi,
There should be a symbol on your camera that looks like a lightning bolt in one of the displays. Simply choose that option until you get an option with a circle with a slash through the lightning bolt. This is the flash off setting.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 16, 2008 | Cameras
Canon SD1000 flash not working
This happened to my SD1000 and I followed the step by step instructions shown here:
http://www.ifixit.com/Guide/Replacing+Canon+PowerShot+SD1000+Broken+Flash+Unit/7778/1
and when I got to step 15, I found that the small plug that connects the flash to the camera body had been disconnected when the camera had been dropped. I simply pressed the connection back in tight and reassembled the camera - and it works. Maybe this happened to yours too??
May 24, 2008 | Canon Cameras
Pentax S4 no flash problem
Well this camera has no manual controls so it's merely compensating for the lack of available light by lowering the shutter speed. I don't think there's very much you can do about it -- maybe you can try to lower the EV -/+ setting (I forget what it's called, it makes your image darker or brighter). If the camera didn't lower the shutter speed you would simply get dark pictures where you can't see anything
Sep 08, 2005 | Pentax Optio S4 Digital Camera
Fuji FinePix A340 Digital Camera Logo
270 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
