Pump runs as soon a power applied - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
Possible there is water remaining on the sump , possible the pump is clogged or finally this can be due to failure of the program controller module.
You need to isolate the case- the pump and the controller- to confirm the fault.
Posted on Jan 12, 2013
Testimonial: "It would seem that the control module is faulty. Machine is now in the rubbish tip."
  • clive45 Jan 12, 2013
    Don, thanks for the info, can you explain a little more re the isolating of the case and pump please.
2004 LAGUNA 1.9 dci wont start runs on easystart but cuts out soon as its not being applied - changed fuel filter, pump is working fine
If it runs on either, then it is the fuel pump or the lines is pinched or restricted some where. Fuel pumps an pump, but is it putting out enough pressure.
Mar 27, 2016 | Cars & Trucks
Chevy Silverado 2002 2500 shows trouble code, P0230, and P0300
P0230 - Fuel Pump Primary Circuit Malfunction Symptoms - Engine Light ON (or Service Engine Soon Warning Light) Possible causes - Blown Fuel Pump fuse
- Open Fuel Pump Monitor Circuit
- Faulty Fuel Pump Relay
- Damaged ECM. P0230 Description The Engine Control Module (ECM) provides ignition positive voltage to the coil side of the fuel pump relay. When the ignition switch is first turned ON, the ECM energizes the fuel pump relay, which applies power to the fuel pump. The ECM enables the fuel pump relay as long as the engine is cranking or running, and crankshaft reference pulses are received. If no crankshaft reference pulses are received, the ECM de-energizes the fuel pump relay after 2 seconds. The ECM monitors the voltage on the fuel pump relay control circuit.
Please go to this LINK for P0300 diagnosis.
Feb 16, 2012 | Cars & Trucks
Fuel pump not getting power.Replaced fuel relay and pump. computer code was reading cam position sensor. I dont believe that would cause a no power to fuel pump. It is trying to turn and it will turn with...
If it is similar to Quest, the fuel pump runs for 5 seconds when you turn the key to ON. Then, unless the engine is running, the pump shuts off. It runs when the key is in START position though. Can you hear the pump run for 5 seconds when you turn key to ON? Listen carefully for the hum of the pump in the tank.
Normally, the power relay powers up the PCM and it applies power to the fuel pump relay. Then you get power to the pump.
Also, look at owner manual for all fuses that apply to fuel pump system.
Jan 05, 2011 | 1998 Nissan Pathfinder
1994 buick park avenue . driving home and shut off
how did you jump the fuel pump relay, by bypassing the relay or by applying power to contact that closes the relay? If you bypassed the relay completely you need to b ench test the relay you can do this easily by using any 12v dc power source. If you tested the fuel pump relay by applying power to the relay and the pump run and developed pressure. I suspect a wiring or ground issue. Good luck
Oct 07, 2009 | 1997 Buick Park Avenue
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
Seems that my R-40 is not pumping fuel
You must set the pressure! If the heater runs with your compressor connected, but won't when the pressure is disconnected, well.......
Setting the pressure is easy!
Jan 15, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Power Supply Keeps Tripping Fuse
Freeze the capacitors is a trick worth trying. These usually are the problem
the way you run this is too use freeze spray to freeze each capacitor one at a time . Turn the TV on and if it doesn't trip for a few second longer you know that is the capacitor to change. Freezing capacitors only helps identify the fault if it is a capacitor issue (usually is with power on TV's)
Dec 24, 2008 | Philips 32MF231D Television
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
