Question about Mirage FRX 7 Speaker
Where can I get a replacement tweeter for a FRX 7 Speaker?
The FRX 7's are no longer sold anywhere, where can I find a replacement tweeter?
Tweeter no sound but speaker no problem
In the most general, basic sense, I would be assuming that this is just one speaker and not 2 with this problem, or 3 or more.
Only way to get the ball rolling is pull the tweeter from the cabinet, checking to make sure all wires are connected at the tweeter and inside the speaker.
If that is the case, then you would need to determine if this is the tweeters fault, or its crossover (thing that divides the sound into whats right for the woofer and what the tweeter wants).
If you have a multi-meter, you would disconnect the wires from the tweeter, set the meter to ohms and touch a probe to each speaker terminal. No action means burned out tweeter, 100% action means burned out tweeter, a reading slightly less than the rating on the back of the tweeter (for instance an 8 ohm tweeter would show anywhere from 6 to 8 ohms on the meter) means tweeter is good.
If you have no meter then take the tweeter from the good speaker and swap in place of the bad one, making sure you respect + and - connections.Its a little risky this way,since if there is something wrong in the speaker it may hurt the good tweeter..(the meter is the safer bet). If it works, then you need a replacement tweeter, if not the problem is either wire connections inside the speaker, or something is wrong with the crossover.
Nov 03, 2014 | Audio Players & Recorders
Parts
It is probably easier to make one.
May 01, 2013 | Mirage FRX 7 Speaker
Tannoy v1 reduced brightness from one tweeter, diagnose? replace? honestly unsure if broken tweeter is the duller one or the brighter one, help?
I assume you have more than one of these speakers. If so simply remove the tweeters from the two speakers and swap them around. If the other speaker acts up then, you know the tweeter is faulty. However if it stays on the same speaker it's the crossover that's the problem.
Jun 11, 2017 | Audio Players & Recorders
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
I loaned my fender passport 300 to some friends. They said they ended up using it as a mixer on a larger system. Now one speaker works normally on one output. when i switch that same speaker and wire to...
It would appear they've blown one channel on the Amplifier and one Tweeter on your Speaker. It's more than likely that the Tweeter has blown first and overloaded the Amplifier.
The Tweeter shouldn't be a problem to replace (eBay more than likely) and you'll probably be better getting a new pair and replacing them both.
The Amplifier could be a different issue depending what Country you're in and your Technical ability?.
If you need any further assistance once you've opened the unit then just ask.
Please leave feedback
Cheers
Andy
May 08, 2011 | Fender Passport P-10 Professional...
I have wharfdale atlantic 400se. The tweeter is no longer working. How do i work out if it is a cross over or the tweeter
If there was a traumatic high-volume event that preceded this problem, I'd guess the tweeter died.
If you can access the connections on the tweeter and you have an ohmmeter, you could disconnect the tweeter and measure across the the terminals. A shorted or open voice coil = dead tweeter. A measurement near the stated impedance is probably ok.
If you have NO ohmmeter, you could carefully connect the output of one amplifier channel directly to the tweeter and just scooch the volume upward slightly from silence while playing something with very little bass in it. If you hear it, the tweeter is alive.
Apr 18, 2011 | Wharfedale Atlantic 100 Rear Speaker
KEF KHT6000ACE TWEETER DIED. HOW CAN I GET A NEW SPEAKER?
if the original KEF tweeter is no longer available there are other brand tweeters that should fit as a replacement option. just contact a repair center (us) and you can get options.
cathy@speakerex.com
Jun 13, 2009 | KEF Audio KHT6000 Speaker
I have a kenwwod AX-7 home theatre systems. the right side top speaker (tweeter) on one side does not work. i'm thinking there is a fualt with the amplifier on the right side.
If the only problem is the tweeter, and the woofer is still working, you do not have a problem in the amplifier. The problem is the speaker. The tweeter is blown or you have a problem in the cross over network in the speaker.
You can always switch the speakers and connect them to the opposite channel. You can do this very easy at the back of the receiver where the speaker wires are at. Put the left speaker wires on the right speaker and the right speaker wires on the left speaker. If the same speaker still has no tweeter you know that the speaker is the problem.
The only way this could be a problem in the amplifier is if you have two different sets of inputs for each speaker, one being the low end for the woofer and the other being the high end for the mid range and tweeter. That would mean you have two sets of speaker wires going to each speaker. Each set of speaker wires would have a positive wire and a negative wire for a total of 4 wires going to each speaker. I don't remember this system being set up that way, but I could be wrong.
I hope this was helpful, you should be able to get the speaker fixed at an authorized Kenwood repair center in your area for a reasonable price. As a guide, my shop only charges $25 for the labor plus the cost of the tweeter to replace a tweeter. Any other shop should be similar. Kenwood does sell replacement drivers for almost all of their speakers.
Jun 21, 2008 | Kenwood Audio Players & Recorders
M-Audio MX8a tweeter replacement
Remove the six hex screws from the plastic front speaker housing. It\'s the piece with the speaker\'s make and model imprinted.
Gently pry the cover off. The blue LED light can be easily freed by gently prying it loose from the back of the plastic housing. You\'ll notice the two wires connecting your tweeter. Don\'t pull too hard on the cover while the tweeter is still attached to prevent detaching the wires. Instead, take very short, stubby Phillips head screwdriver and remove the two screws holding the small plastic brace against the back of the tweeter. It\'s a tight fit. Don\'t pull too hard on the wires! Next, push the tweeter out from the front, touching only the extreme outer rim. Or, use needlenosed pliers to grip the heat sink on the back of the tweeter and gently pull from the back. The tweeter has a very powerful magnet. Find a small but robust rectangle made of ferrous metal. Large enough to span the front diameter of the tweeter. When the speaker magnet grabs the little metal plate, adjust the plate until the buzzing stops. This means of course that you have to turn the power to the speaker on.
May 28, 2008 | M-Audio Studiophile BX8a Speaker
64 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
DaveMc3
DaveMc3
berggei
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
