Question about Tools & Hardware - Others
Setting a cutting depth with the silverline half inch router model 675059
3 Suggested Answers
  • 33 Answers
SOURCE: I have Poulan electric chainsaw
you can get a blade sharpening file that has the degrees on it.i usually do 20-40 strokes per tooth an that seems to be suffecient.you can find the file at just about any hardware store
Posted on Jan 10, 2009
  • 20 Answers
SOURCE: set for maximum depth &
time to rebuild
Posted on Dec 11, 2010
While I'm cutting a 2x4 the blade stops or catches on something? It's happened so many times.
Dull Blade most likely
Wrong Blade maybe
Wrong cutting depth setting on blade
or the way your using the saw
Oct 29, 2014 | Skilsaw "5150" Circular 7 And 1/4 Inch
Ryobi manuals
For which model Ryobi product do you need the manual? Many manuals are available here: https://www.ryobitools.com/outdoor/support/manuals . Just searching for Router gave a number of options. Since most fixed base or plunge routers will adjust similarly for a given style, you should be able to find some information that applies to your router.
I hope this helps.
Aug 01, 2014 | Linksys Computers & Internet
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Dec 10, 2012 | Sears Craftsman 7-1/4 in. Circular Saw...
Router base depth won't hold
I feel your pain! This is not uncommon. If the bit is slipping out of the collet, it is probably due to a dull bit. The 1/4 inch shanks are more prone to this than the 1/2 inch ones, which is why most new routers use 1/2 inch. (Think about the large size as being analogous to a larger wrench being able to exert a greater torque.) However, if the problem is the housing slipping on the base, you can try wedging a little piece of sandpaper under clamp. If the clamp has a thumbscrew, use a wrench on it to tighten it just a bit more than you could possibly do it with strong fingers. It was just this problem that inspired me to ditch my old Craftsman for a Porter Cable. Good luck!
Nov 05, 2012 | Tools & Hardware - Others
Black wheel in the center of router. ??
It controls the depth of cut. Loosen the clamp at the back of the router and turn the motor until the bit touches the workpiece. Tighten the clamp. Turn the wheel until the line on the motor housing is at zero on the wheel. Loosen the clamp and turn the motor to the depth (on the wheel) of your desired cut,ie 1/4 ". retighten the clamp and your cut is set for 1/4th inch.
Feb 01, 2010 | Porter Cable 690LR Router
I am running a six inch blade width horizontal band saw in a sawmilling application, resawing flitches to thinner boards. Average depth of cut about eight inches. What blade life (swage set steel) should I...
This depends on the type of wood you are cutting. Hardwoods , like oak, will dull the blades faster and require a change after about 3 months if used daily 8x7 but you can get a longer cutting time IF the blades are carbide steel. You can add life to the saw teeth by keeping them clean and free of sap buildup too.
Specially when cutting pine.
Jul 12, 2009 | Saws
How can i 45 degree champher 1 mm laminate with laminate trimmer
Use a 45 degree 1/4'' shank router bit with bearing and adjust cut depth to desired depth. you may want to do a test cut on a scrap piece to make adjustments before you make the intended cut.
Jun 27, 2009 | Porter Cable Porter-Cable 309 3.8 Amp...
I have Poulan electric chainsaw model 1625. I am wanting to sharpen the chain but our local guy only deals in another brand so does not have information on the Poulan. What he wants is : -the catch setting...
Jan 09, 2009 | Poulan 1630 16" Chain Saw
Tools & Hardware - Others Logo
27 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
