Question about Home Security
Paragon safe won't open - Home Security
When I close the safe it doesnt stay locked when i close the door
heres a copy of the manual for this safe , but if it wont lock back its probably telling you the battery's are low
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Jan 08, 2016 | Paragon Lock & Safe SureDrop 7875 Digital...
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Paragon alarm instructions
To reset turn power off and remove cover, Remove battery and then remove small black jumper from the middlle of the cicuit board. Power back up with battery and put jumper pin back.
Code will be 1234 for user code and 9999 for engineer code
Thanks\
firoz
Apr 30, 2014 | Computers & Internet
Trying to open the safe, it's not opening and keep beeping?
you only get three chances to enter combo correctly then you must allow it to rest for 30+ minutes (even if you have correct combo)
Sep 18, 2013 | Paragon Lock & Safe SureDrop 7925 Digital...
The relay on my Paragon 1015-00RS timer has gone bad,, where can a purchase another one
You won't be able to find parts for that timer unless e-bay is selling used timer.
Patriot supply sells new timer, Aug 2011:
http://www.patriot-supply.com/products/manufacturer_detail.cfm?manu_id=191
Paragon is no longer making timers and parts except defrost timers.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic crossover timer is 120Volt T1975, which sells for less and has replaceable 156T1978A trippers and WG733 clock motor. Relay is not replaceable part.
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour/t1900%20t1970%20series.aspx
Aug 15, 2011 | Paragon 1015-00RS Indoor Multi Operation...
Hi. I have a paragon 4001-00 timer hooked up to my pool filter. It's worked great for the last 25 years but recently it has become finicky. It will always turn off, but sometimes it won't turn...
If new X2772 tripper hasn't solve problem, it might be time for new timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4001-00 is 120Volt single pole single throw timer in Nema1 indoor enclosure
Wiring terminals 1 2 3
Black Hot wire from breaker connects to terminal 1
Black wire going to load connects to terminal 2
White neutral wires connect to terminal 3
Crossover Intermatic timer is T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Wiring terminals A 1 2
White neutral wires connect to terminal A
Jul 06, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Home Security Logo
150 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
