Mackogo remote control
I misplaced my tv remote control while it was in child lock so now i dnt find remote control .and it switched off now it is in standby.i will appreciate if u can help me.
Sparky-UK
  • 129 Answers
SOURCE: need code to link my bush tv with a kameleon remote control
Hello, you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
IrishDruid
  • 2712 Answers
SOURCE: child lock on tv
All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Posted on May 24, 2008
  • 166 Answers
SOURCE: child lock to unlock
YOU WILL NEED THE DEDICATED REMOTE CONTROL
Posted on Jun 13, 2008
SOURCE: Child Lock on TV
HOLD DISPLAY BUTTON ON REMOTE UNTIL LOCK GOES AWAY
Posted on Oct 02, 2008
SOURCE: 27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
i need the answer for this problem i have a 27" tv and the original remote is lost. recently hit child lock on mistake through tv buttons. now cant turn tv on. tried a universal remote but unable to get tv to respond
Posted on Nov 23, 2008
Megapower. how do I remove the child lock without a remote?
How to reset "Child lock" on TV without remote ' Electronics Forum ...
www.electro-tech-online.com > ... > Repairing Electronics
Apr 8, 2010 - 21 posts - ‎11 authors
I opened the TV, but no "switch" on the PCB to do a "reset to factory". ... You almost certainly need the remote, and also the service manual that .... and I was able to get into the menu by remote and to disable the Child lock.
How to disable child lock on Magnavox 27MS343S without remote - TV ...
www.tv-forums.com/.../How_to_disable_child_lock_on_Magnavox_27...
Sep 23, 2012 - 7 posts - ‎3 authors
Hello, I have accidentally turned on the child lock (not parental lock) on my Magnavox 27MS343S for which I do not have a remote. Since the ... panasonic television child lock
Apr 21, 2012
Apr 8, 2010
More results from www.tv-forums.com
Jan 01, 2016 | Televison & Video
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
Goodmans 42" LD4 255 HD.\r\nlost remote and using
Yes,ur tv does require a tv orginal remote will help u to used,but the child lock mode must have a secret codes to enter it.Can't turn tv on,must have the tv original remote to enter child lock secret codes though.Tries Goodmans website look for there 1-800.. call ask their customer service they can help to erase the child lock secrect password,if u don't know it.Try website Remotes.com to buy the tv original remote.
Jul 18, 2011 | Televison & Video
MY TV IS LOCKED WITH A CHILD LOCK AND I LOST THE REMOTE TO UNLOCK THE TV PLEASE HELP.
Goto the near service center and a new remote of your tv brand and unlock your tv by child lock. its the simplest solution for your problem
Jan 06, 2011 | Televison & Video
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
Child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
May 31, 2008 | Philips Magnavox Learning Universal Remote
Child Lock issue
Unfortunately the Child Lock facility disables the buttons on the TV.
You should be able to get a replacement remote control from an authorised Philips dealer, or you could try a universal remote control form most electrical retailers. Philips make a range of universal remote controls.
Instructions for activating and de-activating the child lock are in the manual. If you don't have the manual, download it here:
https://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox child lock tv
my remote control doesn't work, and i can turn the tv on because i lock to just use with the remote control. How can turn the tv on if i do not have a remote control?
Jan 20, 2008 | Philips Magnavox 27MS343S 27" TV
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
