Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Ethernet controller error in device manager tp-link wn353g
  • Belkin Master
  • 7,733 Answers
  1. Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking DM If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. In Device Manager, locate the device under Network adapters, and then double-click the device name.
  3. Click the Driver tab, and then click Update Driver.
  4. In the Update Driver Software wizard, click Browse my computer for driver software.
  5. Click the Browse button and go to the location on your computer where you saved the new driver files.
  6. Click OK, and then click Next to install the driver.
Posted on Feb 01, 2013
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
Tip
How to Repair a dead TP Link TLPA21 200Mbps Mini Powerline ethernet
TP Link TL PA-211 Powerline Ethernet Adapter tutorial
on Apr 25, 2014 | TP-LINK TLPA21 200Mbps AV200 Mini...
Does a Ethernet Switch(Unmanaged) have a default IP address?
There is a user guide on the tp-link web site. It looks as if this is just a layer-2 switch (ethernet) and there is no user configuration to enter. The IP addresses would come from another device on your LAN. A router or a server that supports layer-3 (IP) would issue addresses by running a DHCP server process on it.
Nov 02, 2013 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
TP-LINK TL-WN321G - Hi-Speed USB - 802.11g driver not install in window xp
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"
Apr 03, 2013 | TP-LINK TL-WN321G - Network adapter -...
Download TP-LINK TF-3200 Ethernet 10/100 Mbps PCI Card
http://download.cnet.com/smc-ez-card-10/3000-2112_4-70830.html
http://download.cnet.com/allied-telesyn-at-2700tx/3000-2112_4-64130.html
if these drivers are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: ethernet driver
you might have to try a few times to get it right
hope it helps
Jul 05, 2012 | TP-LINK TF-3200 Ethernet PCI Network...
Code 31 TP-Link TG-3269
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
while you are there
make sure you Ethernet is enabled in bios
restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
i
hope it helps
Mar 19, 2012 | TP-LINK Gigabit Lan Card (10/100/1000)...
Reinstalled vista and now my Internet won't work pc keeps saying plug cable to local and I have all plugs plugged in please assist
Ensure that you have the correct drivers loaded for your ethernet adapter. To do this go to the device manager.
  1. Click on Start and then Control Panel.
  2. Click on the System and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simply double-click on the Device Manager icon and then proceed to Step 4.
  3. In the System and Maintenance window, click on the Device Manager link near the bottom of the window.
Once you're there, check for any signs of a Question mark (?) or a yellow yeild sign with an exclamation point (!) beside it. It is likely that the correct ethernet controller driver is not loaded. If there is such a problem, search for a driver on the web that suits your ethernet controller, download it, and install it. If you need help with this, post back...I'll be glad to help.
Regards,
DP
Aug 19, 2010 | E-Machines eMachines Desktop PC
No Audio Device for my DELL opti GX60. and no multimedia audio controller same as yellow mark ethernet controller.
For that first uninstall driver for ethernet controoler and audio driver from add remove program.
Also uninstall both from device manager.
Right click on my computer then click on property then hardware ->device manager then uninstall both from that list.
Then download driver from below link.
Click here
Click on above link and select yourt operating system and download audio and ethernet driver then install.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Dell Optiplex GX60 Refurbished Intel...
Fast ethernet LAN drivers not installed and gives error code 10
Go to setting,control panel,system,device manage then click the network adapter,then properties,in resources uncheck the box "use automatic settings" then click the change setting then "edit input/output range" and try using other value with no conflicting device then click ok.Then go back to device manager and check if the yellow exclamation point is still there
Apr 18, 2009 | Computers & Internet
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
65 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
