What is compatible processor and memory as well as agp card on ASUS P45533-MX
  • 3,606 Answers
Hello you can read the cpu list here:
http://support.asus.com/cpusupport/list.aspx?SLanguage=en&p=1&s=15&m=P4S533-MX&os=17&hashedid=n/a
You can use any AGP card for this mainboard.
Just make sure the driver is supported for your windows.
Good luck
Posted on Jan 12, 2013
ardmax
  • 155 Answers
SOURCE: ASUS P4V533-MX Motherboard
You can download the manual from here and see page 2-11.
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/P4V533-MX/e1376_p4v533-mx.pdf
Please enter in the BIOS and go to this screen
Be sure that in the BIOS you have set AGP 4X and Primary Graphics Adapter AGP.
Let me know if you need further help
Posted on Oct 31, 2007
Nic61
  • 1073 Answers
SOURCE: Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Nic
Posted on Feb 06, 2009
slywil091
  • 112 Answers
SOURCE: i have a ASUS P4V533 MX who has i DDR ram
no you wont
Posted on Jun 29, 2009
zner_16
  • 16 Answers
SOURCE: Asus M2N-MX se plus board.... compatible with GF
maybe it is an AGP slot, there is also a pci-e slot.
Posted on Jul 13, 2009
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
Posted on Sep 05, 2009
Vga card
Look for a AGP x8 graphics card with 512mb memory. Or more.
Jun 18, 2013 | ASUS P4VP-MX Motherboard
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
9600 graphics card compatible for asus p5gz
hello, the 9600 graphic card his compatible if you are using AGP slot.
Aug 10, 2009 | ASUS P5GZ-MX Motherboard
Jul 13, 2009 | ASUS M2N-MX SE Motherboard
What memory stick and graphic cards to get
Your motherboard has 3 PCI slots. Any card you install can only be a regular PCI card.
The RAM in your motherboard has to be DDR (333 or 400) 184 pin DIMM's.
Here is a link for your motherboard manual:
Asus P5P800-MX Manual
Layout pic is on page 1-7. Info on your memory is on page 1-15.
Thanks for using Fixya.
May 10, 2009 | ASUS P5P800-MX Motherboard
About AGP grapics
Kababayan:
This is the specs of motherboard:
ASUS S478 VIA P4V533-MX Motherboard The P4V533-MX supports VIA ProSavage8 for quality integrated graphics, 533MHz Front Side Bus, Intel Hyper-Threading technology, DDR SDRAM, AGP 4X, USB 2.0, 6-channel audio and 10/100Mbps LAN, the P4V533-MX is an all-in-1 solution for system builders.
Eto naman Specs ng Video card mo:
Product Name : X1650 PRO 512MB AGP
Video Memory 512 MB DDR2
Bus Standard AGP 8x/4x
Pwede yan...
Happy Fixya...
Jan 22, 2009 | ASUS S478 VIA P4V533-MX Motherboard
Pc upgrade
Hi ****, you can increase you system speed slightly (Depending on the total memory speed of the card), by adding an AGP 4x video card & setting your bios to boot to AGP. See page 2-16 in your manual. Change, Init Display First to [AGP]. Doing this will disable the onboard - integrated video card. (Doing this will also free your system memory which is used to run the onboard graphics card). Increasing your system memory to its max of 2GB will help as well. Here is Crucial's memory link for your board. http://www.crucial.com/store/listparts.aspx?model=P4GE-MX You should increase the CPU if at all possible to its max speed in-order to see an over-all increase of system performance. (This is not what you asked for, so I'll only include Asus link for supported CPU's, for the P4GE-MX motherboard). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P4GE-MX Don't expect lighting speed but you will notice game playing speed much better. Programs should load much faster, ECT. Upgrading the AGP must comply with 4x/8x (+1.5volt only). Please see page 1-12 in your manual. Looking for XFX video card is best because it carries a lifetime warranty. Try this link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150210 You can continue to search for an XFX Geforce cards. (Best on the market for their lifetime warranty). Good luck ****! Though the AGP slot is faster than a PCI slot, you may find an XFX PCI card with more video memory on it. Some even run DDR3 & DDR3 memory. Mike
Sep 14, 2008 | ASUS P4GE-MX Motherboard
Video board
Any AGP or PCI graphics cards will work,, you board does not support PCI EXPRESS,, so feel free to chooose any graphics card that you may like once its AGP or PCI ..
Jul 15, 2008 | ASUS P4SP-MX Motherboard
Compatible video cards
This motherboard has an 8x AGP slot. So any 8X AGP graphic cards will suit this mobo. As your local reseller for any 8x AGP based graphic cards from ATI or Nvidia.
Dec 26, 2007 | ASUS P4V8X-MX Motherboard
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
